Pop-up Assembly Does Not Fit
Lee Roy
I just installed a new Bates sink in a marble vanity top. The flange for the pop-up assembly is flush with the sink drain except in the very front where there is a 1/16th to 1/8th inch gap. The manufacturer for the faucet (Brasstech) recommends only silicone sealer for flange. Can I or should I seat the flange with sealer, or get a replacement sink? Is there another solution?
Secondly there is a gap of 1/4 to 1/2 inch between sink overflow and pop-up. Is there something I should be using to fill that gap so water does not bypass?
Thanks in advance for your help.
Lee
Verdeboy
I'm not familiar with a Bates, but I always use plumber's putty for pop-up flanges. I apply a bead of it just under the flange on top of the sink and another bead above the rubber seal on the bottom to fill in any abnormalities under the sink.
Patrick88
Webster Ma.
I just checked out the Bates pages a little and it looks like most of the sinks don't have an over flow. I would change the pop-up to one with no over flow port.
