Plumbing Stack
R3Improvements
DIY Junior Member
Illinois
r3improvements.com
I'm remodeling my attic bathroom. In order to maximize my bathroom, I would like to put an elbow in my existing cast iron plumbing stack, run about 3feet of horizontal pvc, and then put another elbow in and vent it through the roof. The stack currently runs right through the middle of my attic bathroom. So by moving it over 3 feet, I can create a better floor plan. Is this against code to use 90 degree elbows in the main vent stack?
Thanks.
Seaofnames
DIY Senior Member
Mission, BC
www.boilermakers359.org
It is ok as long as there is some pitch to the horizontal run and it is about 40" above the floodline of the fixture(check your local code for that)
Also make sure if you are putting a new hole in your roof the stack goes up high enough, as there may be a code in your area that wants it higher than minimum code.
In my area(Vancouver Canada) they require cast iron behind the walls because it isnt flammable. This is just a commercial thing, but I'd still check with your local inspector to see if they want cast or if PVC is ok.
R3Improvements
DIY Junior Member
Illinois
r3improvements.com
Can the slightly pitched horizontal section be at the same level as where the toilet ties in or does the horizontal section need to be 40" above this connection?
Thanks.
You can use 90 bends above the flood level.
