I found an old post on here that said not to use plumbers putty on a plastic tub as the oils would eat the finish and leave cracks. Use silicone instead.
I installed a tub drain using plumbers putty to seal the strainer about a month ago. The tub is fiberglass w/ (I think) acrylic gel coat finish. Am I going to have a problem down the road?
If so how can I clean it off and replace w/ silicone? Also, is this just regular silicon caulk or is there a special silicone putty to use in this case?
Thanks,
Joel
Thanks,
Joel
