Plumbers putty on fiberglass tub?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by jwray, Jun 3, 2007.
  1. jwray
    jwray New Member
    Oct 25, 2004
    Virginia
    I found an old post on here that said not to use plumbers putty on a plastic tub as the oils would eat the finish and leave cracks. Use silicone instead.
    I installed a tub drain using plumbers putty to seal the strainer about a month ago. The tub is fiberglass w/ (I think) acrylic gel coat finish. Am I going to have a problem down the road?
    If so how can I clean it off and replace w/ silicone? Also, is this just regular silicon caulk or is there a special silicone putty to use in this case?
    Thanks,
    Joel
  2. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    Depending on the quality of the finish of the tub usually has a bearing on what plumber's putty does to the finish. Most times it will yellow the surrounding area of the tub.
    The silicone goes on the same exact method the plumber's putty went on, just don't mess with the excess until an hour later so you don't get that all over the tub.
  4. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    Use G.E. 100% silicone for tub and bath.
  5. construct30
    construct30 New Member
    Jun 16, 2007
    NorthWest PA
    I only use 100% silicone. Some plumber's putty does say it is safe for use on fiberglass, but I find it can dissolve in the water and start to leak. I threw away all my plumber's putty and use the silicone on everything including the kitchen sink. Don't just use any kitchen and bath caulk, only the 100% silicone.
    mark
  6. molo
    molo Member
    Sep 23, 2006
    Cold New York
    What is the best way to get it (silicone) off a stainless sink if it was smeared on at installation of the faucet? It is dry now.
    TIa,
    Molo
  7. srdenny
    srdenny Plumbing Contractor
    Sep 11, 2004
    Plumbing Contractor
    SF Peninsula
    Next time use this:
    Sta Put® Ultra™
    A unique, professional grade non staining plumber’s putty that is safe for most types of plumbing fixtures and surfaces. Unlike all other plumber’s putty Sta Put Ultra is oil-free and can be used without pre-treatment. This includes natural, porous surfaces such as stone, marble, granite, plastics, rubber, and fiberglass, as well as grout and on manufactured sinks, shower bases, countertops, and other surfaces. Molds easily, remains permanently soft, malleable, and flexible. Sta Put Ultra does not melt, rot, crumble, dry out, or shrink. Easy to clean-up. Does not leave a greasy residue on hands or surfaces. Meets or exceeds Federal Specification A-A-3110 (formerly TT-P-1536A).
    U.S. and foreign patents pending.
    http://www.herchem.com/Products/putty_epoxy.html
  8. MattAlexander
    MattAlexander Plumber
    Jul 20, 2007
    Fresno CA.
    Plumbers putty is fine! You will not have any problems down the road. I have installed litteraly hundreds of fiberglass tubs and have never had a problem with using putty. Maybe 50 years from now the putty will be dried up but until
    the actual seal is disturbed deliberately you will not have a leak. By the way, when and if that ever happens all you have to do is loosen the finish drain with a spud wrench and give it a fresh ring of plumbers putty and tighten it back up. VIOLA.
  9. frenchie
    frenchie Jack of all trades
    Dec 30, 2006
    Caretaker
    Molo -
    Sucks to be you: a razor blade, a very delicate touch, and a whole lot of patience...
  10. GrumpyPlumber
    GrumpyPlumber Licensed Grump
    Jun 18, 2007
    Plumber, self employed
    Licensed Grump
    The ONLY thing plumbers putty should NEVER be used on is granite/marble.
  11. bradak
    bradak New Member
    Oct 1, 2008
    BC
    is this a marketing ploy or liability issue
    Seems to me there is a lot of mixed feelings on using plumber's putty with acrylic tubs. I called up the manufacturer of acri-tec to find out if I could use plumber's putty on the drain. They said it would be fine. Has anyone ever seen a yellow stained acrylic tub from plumber's putty? Can someone post a photo of it? How about a deteriorated mushy eaten drain hole from the putty? Maybe the plumber putty manufacturer just doesn't want a claim due to a lower quality plastic tub staining. The directions say plastic, not acrylic. There are many different types of plastics out there. Many of them hold oil and others hold acid or caustic. What's your motor oil come in? or your cooking oil? Well, I used it on the acrylic tub drain. I also used it between the overflow abs tub side flange and the tub wall. Silly rubber gasket between overflow shoe/elbow and rough tub fiberglass outside wall wouldn't seal.
  12. Cass
    Cass Plumber
    Nov 12, 2005
    Personally it would be an extremely rare situation where I would use silicone...
  13. Racer814
    Racer814 New Member
    Dec 24, 2006
    I use putty except on natural stone surfaces, however I use silicone on shower drains as they are prone to work loose over time...it's just the way I was taught frankly and it works as good as anything else...I don't really understand the need for silicone on basket strainers and such and want to choke the sh8t out of someone when I have to go behind them.:D
  14. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Silicone, 4" sheetrock screws, duct tape, JB Weld. Four of the most mis-used products in history.
    Silicone should never be used under the drain or for that matter on any part of the drain. Nor should it be used under the faucet unless you plan on ripping out the whole fixture next time you need to service it because sure as hell it ain't coming apart without damaging something. I can't count the number of kitchen faucets I've had to sawzall off the deck because someone siliconed the faucet down.
  15. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    I hate it when people glue down drains and faucets with silicone rtv...
    I'd go postal if I saw someone doing it!:mad:
  16. alek
    alek New Member
    Apr 27, 2011
    Kensington, MD
    Don't use silicone
    I have never had any leak from any plumbing joint whether solder, plumbers putty on a drain, etc. until my shower drain showed evidence of leaking. I installed 6 years ago following directions on the drain flange and utilized a small bead of silicone caulk....big mistake. I'm now ripping out my drywall ceiling below the drain to replace. I will use the plumbers putty to replace. Never a problem with the putty on all of my sinks in other locations.
    Silicone did not work for me.
  17. djarvis8
    djarvis8 New Member
    Apr 22, 2012
    Rochester, NY
    Silicone?!
    What if you have to remove it? You won't be able to!
    I've always used Plumber's Puddy without a problem. And it can always be re-applied.
  18. BobL43
    BobL43 DIY Senior Member
    Mar 25, 2011
    Retired Industrial Automation controls/tech s
    Long Island, NY
    Now we know you are a real New Yorker and especially a lon gye lander:rolleyes:
  19. BobL43
    Mar 25, 2011
    Long Island, NY
    American Bath Factory requires you to use 100% silicone on their Acrastone tubs for the drain flange or the warranty will be void if you use anything else and have a problem; go figure.
Similar Threads: Plumbers putty
Plumbing Forum, Professional & DIY Advice Acrylic Tubs - Silicone vs Plumbers Putty Jan 6, 2017
Plumbing Forum, Professional & DIY Advice Silicone Vs Plumbers Putty May 6, 2016
Plumbing Forum, Professional & DIY Advice Plumbers putty on plastic Mar 19, 2012
Plumbing Forum, Professional & DIY Advice Silicone or plumbers putty? Dec 10, 2011
Plumbing Forum, Professional & DIY Advice Plumbers putty for tub drain, or...? Jun 13, 2011
