Please suggest sprinkler pump...
01sesedan
Tallahassee, FL
I had a Baldor sprinkler pump for over 15 year, finally it quit.
I've check HD but don't like the plastic pump. Lowes has an Water Ace, looks like it's all cast iron but I'm not sure if it's any good.
Was hoping you guys could recommend a replacement pump.
Are they all the same?
Thanks..
Waterwelldude
Well driller,pump repair. and septic installer
Texas
The cast iron pumps, you are more likely to get more life out of. The plastic ones just don't seem to hold up that well.
Goulds, Jacuzzi and Grundfos, are some pretty good ones.
I hear that the flint and wally are ok. Can't say for sure never used the f/w pumps.
Witch ever way you go, go with the cast iron.
Travis
Speedbump
Active Member
Riverview, Fl.
Baldor was the motor on your pump.
I agree with Travis. Plastic is junk and cast iron is better. Big Box stores sell cheap pumps with even cheaper motors on them. Water ace is a Myers with a cheap GE motor on it. Flotec is a plastic Sta-Rite with a cheap motor.
Here are some good Centrifugal Pumps if that's what your looking for. What kind of hook up are you doing, deep well, shallow well, out of lake, pond etc? The right pump for the job is the best one. How many gallons per minute do you need?
bob...
01sesedan
Tallahassee, FL
I'm told the well is about 65' to 70' deep. The yard medium size, not sure how many square feet. It has 2 zones, front and back. Each zone has about 18 sprinkler heads. They are the cheap popups from HD.
Not sure what other information might be needed. Was thinking of going with a 1-1/2hp motor.
Your thoughts..
The centrifugal pump on that site is what we're looking for.
Thanks..
Speedbump
Active Member
Riverview, Fl.
You still haven't told me where the water is coming from. A well, a ditch, pond, river, lake. We need the depth to water from the source to the pump. We also need to know how many gallons per minute each of these heads use. That way we can figure out what size pump you need.
Otherwise, we are shooting in the dark.
bob...
01sesedan
Tallahassee, FL
Its from a well. The well is about 65' to 70' deep.
Each sprinkler head flows 3 gallons per minute.
Zone 1
Front yard
4 full pattern @3 gpm.
15 half pattern @ 1.5 gpm
Zone 2
Back yard
8 full pattern @ 3 gpm
6 half pattern @ 1.5 gpm
Let me know if you need additional information..
Speedbump
Active Member
Riverview, Fl.
We only need the water level in the well now. So your using 34 gallons per minute on each zone.
Using 15 feet as a water level and 40 pounds of pressure, you would need a 1.5hp self priming Centrifugal Pump. If the water level is higher and you can get by with 30 - 35 psi, you might be able to get by with a 1hp.
bob...
tomm
bob...
I'm thinking a submersible would be a better choice for a 70' well?
Speedbump
Active Member
Riverview, Fl.
It depends on the water level and the horsepower you would need for that water level and that amount of water.
With my 1.5hp 30 gpm sub, you are at the limit of the pump for that amount of water at 40 psi.
Do you have a 4" or larger well? And where is the water level standing? How many feet from ground?
bob...
Speedbump
Active Member
Riverview, Fl.
Yes I sell Betta Flo and I was recommending the SFLP 150 if your water level is high enough.
I only recommend self primers if your using them with a timer, not a pressure switch.
bob...
01sesedan
Tallahassee, FL
Yes...got a timer. Are the prices on the site current? Will see if I could find a pump locally. Maybe you could recommend a local vendor? I'm in Miami.
Thanks for you input...
Speedbump
Active Member
Riverview, Fl.
I'm about as local as it gets. I'm in Riverview, half way from you to Tallahassee. I really don't know who would sell them in Miami.
bob...
