skuba
Hi Guys,
I have a little problem in the apartment I rent and I can't find the solution anywhere. Have been to home depot, talked to folks there and they don't know how to solve it.
I was going to install a t-pipe to put a spray, but the hose from shut off valve to toilet tank was really old and it broke. I went looking for a replacement and bought a hose with a 1/2" adaptor. I actually got one of those packages that come with an 1/2" iron pipe adaptor and a 1/2"OD compression adaptor.
But none will fit! One is too big and the other 2 small. The shut off valve adaptor is a 1/2", but it seems to be an old system. Where the nut is actually attached to the hose, it won't come out.
Some people suggested replacing the entire shut off valve with one with a 3/8" adaptor, but I am trying to fix this without having to aks the landlord to shut the water supply for the building.
When I talk about this 1/2" old school adaptor, do any of you know what I am talking about, and know what I need to do for a hose to fit without leaks?
Please see image attached. You can see the 2 adaptor and the original hose.
Sorry that I can't explain it better.
Thanks so much
Thanks so much
