Plaster of Paris Toilet Base -- Who Uses It?
Discussion in 'Toilet Forum discussions' started by wjcandee, Aug 7, 2013.
  1. wjcandee
    wjcandee Wise One
    Apr 27, 2012
    New York, NY
    I'm curious as to the geographic regions in which the plaster of paris toilet base is popular.
    When I was first installing my new Totos, the prick at the local Ace Hardware (idiot) gave me a whole lecture on how you needed plaster of paris to install a toilet. Having been participating in this forum, and having read the Toto instructions, and having seen videos from places like the Home Depot on how to install a toilet, I knew that this was total crap. And yet he mockingly told me that without plaster, I wasn't properly "setting" the toilet.
    When talking to the very-knowledgeable guy from the highly-successful local plumber I have started to use recently (my previous trusted guy seems to be exiting the business, or at least he is rarely-available, so ta-ta), he mentioned that he uses the plaster of paris method to "set" a toilet. (My previous guy said that they did so as well, but at least allowed that many people didn't do so.)
    According to the new guy, the plaster of paris gives you a stable base for the thing, it never rocks, once you put it in you don't have to come back, and it's actually easier to remove, with less potential damage to the porcelain, if you do need to remove it, than using caulk. His main point seemed to be that the method compensated for irregularities in the toilet and in the floor. I asked him if he installed a lot of AS toilets. "Huh?" Never mind.
    Then came the condescending slam: "Let us know if you need one re-installed correctly." Funny, we seemed to have been getting along famously until that point, but he wasn't going to get away with that. Upon further discussion, we agreed to disagree. But geez.
    I pointed out that Long Island seemed to be the only place in the country that I was aware of where this "make a plaster of paris base" procedure was regularly in use. Indeed, when I replaced the three toilets I have replaced, I have had to chip away the old stuff. Plaster of paris seemed an odd choice of material, as well, but that is the term every guy has used, along with the somewhat-archaic concept of "setting" a toilet.
    Anyway, is there anywhere else in the East, the West, the Mountains or the Central States where this method is popular? Is it some kind of old-timey New England thing? I'm curious to know.
    On a separate subject, nobody on Long Island has the slightest idea what an air gap or a high loop is on a dishwasher installation. Not the installer. Not the plumbers. We just went through this last week, and I was plenty surprised. Glad my kitchen drain is running well...
  2. DougB
    DougB Member
    Jun 19, 2010
    Software Developer / Engineer
    Minneapolis - Land of 10,000 taxes
    That's interesting - I recently demo'ed my master bath (1950 - Minneapolis) and I had to chip out this strange material under the toilet. Now that you bring it up - it must have been plaster.
  4. joemcl
    joemcl In the Trades
    Mar 2, 2013
    licensed journeyman plumber
    Pennsylvania
    I have been in the trade over 25 yrs. just outside of philly, and have never seen this.
  5. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    Before your time it was a common practice to use plaster of paris. Some were set with a mixture of plaster and plumbers putty.
    John
  6. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    The previous post sort of validates my thinking that this was used in the days before the caulking that we use today was invented.
  7. Terry
    Aug 17, 2004
    I have never used plaster to set a bowl.
    That would be a tough one if it ever needed to be removed for any reason.
  8. johnjh2o1
    Aug 9, 2009
    Retired
    Florida
    Keep in mind that many of the toilets set in plaster were 4 bolt bowls that were set on lead pipe without a flange and screwed to the floor with closet screws.
    John
  9. wjcandee
    wjcandee Wise One
    Apr 27, 2012
    New York, NY
    Good enough for me.
    The plumber claimed actually that it made removal easier, which I am here to tell you it doesn't. However, having removed three that had been installed that way, you kind of just rock it gently from side to side and it more-or-less frees itself, more-or-less without damaging itself, then you can lift it out. It's a heck of a deterrent to pulling it back up to double-check or fix something, however. It also left a delightful discoloration on a wood floor.
    On one of the 1950s AS toilets, they had actually set the tank in plaster between the tank and bowl, which I discovered when I went to replace the flush valve last year. I guess that was their way of keeping it from rocking. I just chipped it all out, replaced the flush valve, and mounted the tank the way I assume that God and American Standard intended. Turns out that with a decent tank to bowl set and a little trial and error, I was able to get the tank mounted very nicely and very firmly without the need for any schmutz in between.
  10. wjcandee
    wjcandee Wise One
    Apr 27, 2012
    New York, NY
    So it seems to be a really very local issue out here on Long Island -- because you're just two hours away!
  11. hboogz
    hboogz Member
    Mar 12, 2013
    New York
    When I first heard of using plaster, I immediately thought something was not quite right. But, after hearing and seeing several guys using plaster, I think it may be something that's been going on long time. I have seen those plastic shims at HD recently, but have never seen anyone use those.
    Disclaimer: I'm not a plumber, but a very active DIY homeowner.
  12. Gary Swart
    Sep 1, 2004
    Yakima WA
    Shims are only used when a toilet is installed on an uneven floor so it will set level and be solid. The plastic door shims are ideal for this purpose, but other things can be used. Regardless of the material used for shimming, the job is finished with a bead of caulking around the toilet. All toilets based should be caulked anyway, but when shims are used, the caulk serves a triple purpose. The first is to anchor the toilet firmly, the second is to prevent spilled water from getting under the toilet, and the third conceals the shims.
  13. hboogz
    hboogz Member
    Mar 12, 2013
    New York
    Just to confirm with the pros -- is this the caulk that's used ?
  14. wjcandee
    wjcandee Wise One
    Apr 27, 2012
    New York, NY
  15. hboogz
    hboogz Member
    Mar 12, 2013
    New York
    Cool. Thanks!
  16. Gary Swart
    Sep 1, 2004
    Yakima WA
    Don't use silicone. Silicone is very difficult to remove when you need to pull the toilet up. The latex Dap is a good product. You can get it in plastic tubes than don't require a caulking gun. Apply a thin bead and use a wet finger to smooth it out. Water clean-up. Other brands work well too, just be sure it's latex base.
  17. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
    Is the wet finger also the method of choice with PolySeamSeal?
Similar Threads: Plaster Paris
Toilet Forum discussions How do you remove a toilet set in plaster of paris? Sep 4, 2012
Toilet Forum discussions plaster of paris Dec 22, 2008
Toilet Forum discussions Mounting a Toilet: Grout, plaster, or putty? Sep 25, 2009
Toilet Forum discussions Twist and set closet flange & plastering a toilet Apr 16, 2007
Toilet Forum discussions Toilet Model Comparison May 17, 2015
