I had my well pump replaced as the last resort to my water pressure problems and all was well... During the install the contractor had the "pitless" adapter come undone twice after completion with the pump falling down the well. He was using what he referred to as a pitless adapter, but I can find no pictures that look like it anywhere. It looked like an upside down "y". He ended up using the old adapter on the third attempt, which was in much worse condition, but was able to hold the pressure. It has been a week since the install and it is once again leaking at the connection, but since he put a hold down on it, it has not popped off.
I have contacted him and he will be out to make a 4th attempt later this week, but I am unsure if he will be able to resolve the issue under the terms of his contract.
My question is, does anyone have information on this type of adapter that I can do some research on my own, or are there quick and easy fixes to the problem that I can work with the contractor on? He seemed very stumped on why his new pitless adapter failed as he claims hes used it hundreds of times without issue. I want to avoid digging a 6' deep trench if at all possible....
Additional info:
Well depth - 163'
Pump depth - 109'
Static depth - 53'
3/4HP - 2-wire pump
7" well casing
"pitless" adapter set 6' below grade
Additional info:
Well depth - 163'
Pump depth - 109'
Static depth - 53'
3/4HP - 2-wire pump
7" well casing
