pipe size /max length of run for kitchen, Canada Code
Discussion in 'Canadian Plumbing Code Questions' started by Philbert, Aug 7, 2010.
  1. Philbert
    Philbert New Member
    Aug 7, 2010
    Toronto,Ontario,Canada
    hello
    I have been asked to rough in a new kitchen, it has 1 double sink and a dishwasher beside it, the soil pipe is 25 to 30 feet away, I don't want to run 3 inch all the way if it isnt needed , thanks
  2. hj
    Even IF 1 1/2" would be approved, there is no way I would EVER use it for anything other than a vent. I ALWAYS use 2" minimum for my drain lines.
  4. Philbert
    Philbert New Member
    Aug 7, 2010
    the problem I am having is that if I seach online for a quote from the npc I get a vague reference to some "complicated table" in the plumbing code book which I can acces online unless I pay for it or order a copy of the code book for a price of course,if ther is no restriction all the better, although I will likely use 2 inch anyways, ohhh the 25 to 30 foot run is a sloped run not a drop ifin that changes anything
  5. jimbo
    jimbo Plumber
    It is not a "complicated table" at least not in the books down here. Each fixture is desinated by a number which correlates to how much water is likely to go in it. The number is called "fixture units". In the UPC, a kitchen sink is 2 FU. By the simple table, the maximum # of FU on a horizontal 1½" pipe, beyond the trap arm, is ONE. So the sink needs to drain into a 2" lateral. The horizontal length ( with 1/4" per foot slope minimum) is unlimited.
  6. Doherty Plumbing
    Doherty Plumbing Journeyman & Gas Fitter
    Jun 22, 2009
    Red Seal Journeyman Plumber & Licensed Gas Fitter
    Penticton, BC
    1.5" is perfectly acceptable as long as you pick up your vent within 6'.
    I usually have a 1.5" fixture drain picked up by a 2x1.5x1.5" tee.
  7. Terry
    Aug 17, 2004
    I haven't seen 1.5 for kitchens since the 50's in the lower 48, not Canada though.
    Here we use a 2" waste line until the vent, and then a 1.5" trap arm. we are allowed 42" for the 1-1/2" trap arm.
    I guess the Canadian code for kitchen plumbing is pretty weak.
  8. Plumber1979
    Plumber1979 Certified Plumber
    Jul 15, 2012
    Certified Plumber
    Ontario
    im a plumber here in Ontario and its just fine to use 1 1/2 on a kitchen and it 5' for the vent
  9. mikeplummer
    mikeplummer Plumber
    Mar 28, 2012
    Ontario, Canada
    1-1/2" is fine. trap arm max is 5' (1.5m). cleanout required on fixture drain or union p-trap. cleanouts every 20' (6m).. you'll want to make sure your slope is right to keep a kitchen sink line that long, clear of grease etc.
    secondly NPC is not what you need. you need to refer to the Ontario Building Code section 7 - Plumbing
  10. Sean Beck
    Sean Beck Plumber
    Jun 14, 2013
    Toronto, Ontario, Canada
    1.5" is permitted by code providing the vent is connected within 5ft and there is a clean out every 6m. Personally with it being a kitchen drain which is subject to grease build up, I would use 2" with cleanout every 6m.
  11. mikeplummer
    mikeplummer Plumber
    Mar 28, 2012
    Ontario, Canada
    your posts suggest that your reply to the request of the customer should have been " I don't know plumbing - perhaps you should consult a plumber "
  12. hj
    pipe
    The code is a "minimum standard", and I do not know any "competent" plumber who has ever had to snake a sink drain who would use less than 2". With 3" you run into the problem of NO "self scouring" because the velocity is too slow. Use 2"!!!!!!
Similar Threads: pipe size
Canadian Plumbing Code Questions Vent pipe size - Alberta Jan 9, 2015
Canadian Plumbing Code Questions Minimum drain pipe size for a lav Mar 31, 2013
Canadian Plumbing Code Questions I need to know the vent size for a 2 inch shower pipe drain Oct 7, 2010
Canadian Plumbing Code Questions Washer Standpipe and Laundry Sink Drainage Reconfiguration Jan 14, 2017
Canadian Plumbing Code Questions water pipes below electrical panel Oct 6, 2014
