Our pressure tank is leaking
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Crafter_Man, Apr 28, 2013.
  1. Crafter_Man
    Crafter_Man New Member
    Apr 28, 2013
    Our home is on a well. About a month ago our pressure tank started leaking. Some pics:
    Pic 1
    Pic 2
    Pic 3
    Pic 4
    Pic 5
    The tank is located in the basement. I am guessing it was installed in 1989, when the house was built. It is an A.O. Smith Aqua-Air V60.
    Can the tank be repaired? Or do I need a new one?
    In either case, is this a job I can do myself? (I am pretty handy. I have quite a few tools, and have installed copper pipe and plastic drain pipe a number of times over the years.)
  2. craigpump
    craigpump Well-Known Member
    Apr 12, 2012
    Self employed water system tech
    You MIGHT get lucky and find there is a pin hole in the piece of copper tubing between the tank Tee and the tank. However, that tank is pretty old so I would replace it and get rid of those galvanized fittings at the same time. Be sure to put in a pressure relief valve too.
  4. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    Most of those tanks don't last 10 years, so I would say that you got your money's worth.
  5. craigpump
    Apr 12, 2012
    Those Goulds tanks were almost as bad a Sta Rite signature 2000
  6. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
  7. jswordy
    jswordy New Member
    May 15, 2013
    Fayetteville TN
Similar Threads: pressure tank
Pumps and Tanks Well Forum & Blog. Water is life. Helplease....Sprinkler pump and pressure tank Feb 18, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Alternative way to plumb/operate pressure switch (moving tanks)? Feb 10, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Want to change well tank pressure Jan 27, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Wellpump and pressure tank mismatch? Jan 26, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Pressure Tank Jan 25, 2017
