This stub outs are pretty thick. Even though copper life is extremely dependant on water quality. If your water isn't compatible with copper than the thickness is just a matter of timing to failure. We use the stub outs all the time and for about everything. Our water has good compatibility with copper. It can be different literally anywhere you go.
Terry, There is a housing development I did some remodel work in the Kingsgate area and found that the copper tubing in 2 of the homes we worked in had the thinnest copper I'd ever seen! It would deform out of round when trying to cut it with a tubing cutter. I don't think it was worn out either, just manufactured really thinly. I ran into those probably in the late 90's early Y2Ks. I just went and looked at the house on Google street view and they look like the split level homes typically built in the area in the mid to late 70s.. Would be really interesting to see how those homes copper systems are fairing now.I started plumbing in 1974 with copper. Just installed a Bosch dishwasher in a 1971 condo for Pamela. No issues with copper where I'm at.
well CDA isn't going to tell us to go plastic. Going plastic is cheaper , eliminates a joint in the work those are advantages my opinion. Disadvantages of PEX they look crappy , stick out the wall crooked, I think a bit prone to possible damage I don't like the connections for anglestops or any sort of equipment looks crappy . sort of pet peeve . but I cant argue those 2 advantages cheap and saves a joint.
My house has PEX stubs with standard compression stubs I hate them . unless those stubouts are manufactured poorly they shouldn't fail in 8 years a soldered 90 stub out should last 40 to 60 years on average if not more so why those with a PEX end should last that long unless they just cant make them right.
the threaded nipples are great but too expensive the material and the labor is too much .
I think the copper stubs will die before too long in most homebuilding
Far far more pricey i mean if you are doing a kitchen and are a service company charging a thousand or 2 to move some stub outs a foot or 2 no big deal but building an apartment complex or competitively doing tract homes here in Southern CA. you aren't going to screw nipples in and then come back to set finish with a nipple tray and pipe wrenches under every sink . I don't see screwed nipples maybe that's how its done in Montana but never done that way in 50 years here unless its old galvanized or institutional school court house , hospital. Yes you are a far minority but I'd like to do it your way too I'm not going to though You probably do some nice work and have the clientele that will payAs for the price of a brass nipple, it depends on if you are buying 5 or 500 . I don't see how threading a nipple into a DE90 is more labor intensive than soldering in a stub. I realize I am in the minority when it comes to using brass nipples.
I got a little offtrack but yea I think this guy is full of beans He also is pushing PEX B Zurn for expansion says its the most superior way to pipe a house .On this YouTube video, an experience repiper said he doesn't use copper stubouts anymore in PEX repipe jobs because they last as little as 8 years.
Youtube
Anyone else experience this? Is he talking about just the stubouts or is he talking about copper in general, or is he full of beans?
John
Far far more pricey i mean if you are doing a kitchen and are a service company charging a thousand or 2 to move some stub outs a foot or 2 no big deal but building an apartment complex or competetively doing tract homes here in so ca. you arent going to screw nipples in and then come back to set finish with a nipple tray and pipe wrenches under every sink . I dont see screwed nipples maybe thats how its done in montana but never done that way in 50 years here unless its old galvinized or institutional school court house , hospitol. Yes you are a far minority but Id like to do it your way too Im not going to though You probebly do some nice work and have the clientel that will pay
