Open Source Water source Heat Pump Q&As
Discussion in 'Solar and Geothermal Water Heating Forum' started by mike04, Sep 1, 2011.
  1. mike04
    mike04 New Member
    Aug 31, 2011
    Joplin, MO
    I have installed a 5 T water source heat pump in my 2000 foot home and have been using an open source water supply from a seep spring which is about 300 feet from the house and is (the spring) about the size of a six car garage and which flows into a two acre lake. The flow is about 18-30 gpm and maintains a temp of about 55f year round in the spring area. The spring area is only about 18 inches deep.
    I am currently using a water flow rate of 12gpm with a water temperature drop out of the heat pump of 5-8 degrees f. from a 1 1/4 inch feed line. The 12gpm rate is used because the incoming winter water temp is only about 45 degrees at the heat pump.
    I would like to change to a closed loop system in the seep spring.
    My questions are:
    How many loops constructed in the seep spring of what type & size pipe and how long should the loops be?
    Assume the exhaust water would be returned to the seep spring loops through a pipe placed in the lake.
    It took me a year to develop a back flushing filter at the pump in the shallow spring (algae in summer and leaves in winter). I will share that design if anyone is interested.
Similar Threads: Open Source
Solar and Geothermal Water Heating Forum Most Efficient Open Loop Geo System Oct 3, 2016
Solar and Geothermal Water Heating Forum Open system idea - thoughts? Dec 23, 2013
Solar and Geothermal Water Heating Forum In need of SERIOUS HELP! C'mon Guru's share your wisdom - Open loop Geo tale of woe. Aug 3, 2012
Solar and Geothermal Water Heating Forum Geotherm open loop system water pressure problems Jun 29, 2012
Solar and Geothermal Water Heating Forum Which is better for open loop discharge...recharge well or drywell? Aug 3, 2009
