ONE pressure switch controlling TWO pumps?
Discussion in 'Pumps and Tanks Well Forum & Blog' started by NealinNevada, Aug 10, 2009.
  1. NealinNevada
    NealinNevada New Member
    Hi folks,
    I am looking for some advice...I'll briefly explain my situation.
    I have a small ranch in New Mexico which has a water tower and a 3/4 hp submersible pump in the well. The well pump fills the gravity feed tower tank. I now want to plumb this system so that:
    1) I can fill the tower tank using the submersible pump and pressurize the water coming from the tower tank using a small 1/2 hp jet pump to maintain a pressure in the house at 40-60 psi.
    2) I can bypass the tower and use the submersible pump to pressurize a pressure tank and maintain 40-60 psi in the house.
    So, I guess what I want to do is run two water supply systems parallel to each other, using one or the other, but never using both systems at the same time.
    Questions for the experts:
    1) Can both the submersible and the jet pump be run from the same pressure switch or is it better form to run a separate pressure switch for each pump?
    2) Can the same pressure tank be used to maintain house pressure between 40-60 psi (by plumbing the jet pump into the inlet of the pressure tank used by the submersible pump system) or should I plumb separate pressure tanks for each system?
    If this makes no sense to anyone, just shout and I will post a sketch of the system that I have put together. I know I'll need a check valve or two and some gate valves in the system to isolate one system from the other.
  2. valveman
    valveman Moderator Staff Member
    4,380
    Lubbock, Texas
    There are lots of things you can do here but, I can't figure out what you are trying to accomplish?
  3. Thatguy
    Thatguy Homeowner
    1,460
    MD
    1) fill the tower tank using the submersible pump (#1) and
    pressurize the water coming from the tower tank using a small 1/2 hp jet pump (#2)
    #2 downstream of #1?
    Define what elements are in each "system" as you want it.
    So your (separate?) elements are #1 pump, #2 pump, water tower tank, pressure tank, pressure switch and 'house'?
    so #2 is downstream of #1?
Similar Threads: pressure switch
Pumps and Tanks Well Forum & Blog burned out pressure switch Jul 20, 2014
Pumps and Tanks Well Forum & Blog Information on Distance between Pump Pressure Switch and Pressure Tank Jun 16, 2014
Pumps and Tanks Well Forum & Blog Square D pressure switch 9013FSG 2 Jun 3, 2014
Pumps and Tanks Well Forum & Blog Pressure Switch and the Jet Pump-They hate each other May 15, 2014
Pumps and Tanks Well Forum & Blog VFD pump with standard pressure switch? May 12, 2014
