Leaky Boot
- Messages
- 79
- Reaction score
- 3
- Points
- 8
Removed a Sta-Rite last week that was installed April 1971. 47 years of service. 1 hp 3 wire set at 360 ft. LB
I have a factory rebuilt Reda from 1961 still in the original wooden box. I also have a 1/2 HP Grundfos in a personal well installed in 1982, still working.
I'll bet that Sta-Rite probably had an oil filled motor?
Was the ground wire insulated or did it even have one back then? Just wondering if they did this later to save money(cents).
My brother built his home in 1977 and has his original two wire pump. I think it is a Gould 1/2hp. Mine Grundfos went within 6 months, but in all fairness the local stormwater pollution Nazis made me plant the lawn in May of 2016 so I had to water for three months straight to get my lawn established in the driest summer in years. But it was warranteed. It just goes to show you how different folks have different luck.
I suspect it was cycling a lot, not running continuous. It really depends on how many GPM the sprinklers used versus the GPM of the pump and size of tank.running your submersible pump continuous for 3 months straight.
Three wire as in type or quantity? Modern three wire pumps use a fourth wire for ground. Lightning could be common mode, meaning the potential rose on all the wires which might not trip breakers or show damage along the path. My electrical service ground is bonded to my metal well casing with #6 wire so hopefully it takes the brunt of the energy.Actually the well driller believe it was a lightning he strike but that somehow didn't make sense since it is a three wire and the module in the basement didn't fry up
It was definitely cycling on and off a lot those three months of dry summer. Actually the well driller believe it was a lightning he strike but that somehow didn't make sense since it is a three wire and the module in the basement didn't fry up. The bottom of the pump looked like it exploded outward and was visible. I was happy to be fully covered by warrantee. We use maybe 1,000-1,200 gallons a week here in the home and now that my lawn is established I honestly never water my lawn. Occasionally a small patch is replanted or fixed and you know, anyone who is informed waits until autumn for that. Then you might water it 1-3 times for an hour at a time or something. Trying to plant a two acre lawn the week before Memorial Day in upstate NY is futile but you can't argue with the inspectors, and they like tell you that the EPA can fine you 38 grand a day for runoff violations and all that nice stuff.
It could have also been lightning, but usually the pump quits the second you hear the thunder, so there is usually no doubt when lightning is at fault.
