odd leaking faucet, Aqua Dynamic
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by anon125, May 24, 2012.
  1. anon125
    anon125 Member
    Jul 7, 2009
    British Columbia
    if this is on the wrong forum, please move it to the right one!
    the exterior faucets are the kind for cold weather, so they are about a foot long - inside the house.
    the shaft the handlle is on has a little hole in it.
    on one, that is where the water comes out!
    what is wrong?
    thanks
  2. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    Sounds like you didn't remove the hose from it last winter causing the faucet to freeze and break.
    John
  4. anon125
    anon125 Member
    Jul 7, 2009
    British Columbia
    hose was removed - thanks
  5. jadnashua
    A frost free sillcock uses a long shaft on the handle to turn the actual guts of the valve way at the other end. So, if it is leaking, it may need a rebuild kit to replace the sealing washer and or seat. Also, most frost-free sillcocks will still split if you happen to leave a hose on it with a closed nozzle...it then can't drain. If the shaft isn't sloped properly, it can't drain, and could freeze, too.
  6. Terry
    Aug 17, 2004
    Sounds like new parts then.
    You should be able to order them from the manufacture.
  7. anon125
    anon125 Member
    Jul 7, 2009
    British Columbia
    see fountain!
  8. anon125
    anon125 Member
    Jul 7, 2009
    British Columbia
    has anyone seen aanything like this?
    thanks all
  9. Terry
    Aug 17, 2004
    Not really.
    What is the brand name of the faucet?
  10. anon125
    anon125 Member
    Jul 7, 2009
    British Columbia
    do these help
    i suspect that rubber valve on top.
    thanks
  11. Terry
    Aug 17, 2004
    Not really.
  12. johnfrwhipple
    johnfrwhipple BATHROOM DESIGN & BUILD for both Canada & the US
    Jul 20, 2009
    Design Work World Wide: Bathrooms Vancouver Area
    North Vancouver, BC
    Annon I use similar exterior hose bibs on my projects here in Vancouver but prefer the 1/4 turn models. I suspect that that shut is missing a bleeding cap of sorts where you are getting the water stream from.
    Try bringing it to EMCO or Bartle & Gibson for replacement parts.
    Good Luck.
    JW
  13. anon125
    anon125 Member
    Jul 7, 2009
    British Columbia
    thanks....
  14. anon125
    anon125 Member
    Jul 7, 2009
    British Columbia
    does anyone know why the water comes out that little hole in the rod thingy?
    we replaces the end piece where the washer are. did not help.
    thanks all
  15. anon125
    anon125 Member
    Jul 7, 2009
    British Columbia
    Hello again folks!
    well we found a new inner piece and so far it works.
    it does not creak any more when opening/closing.
    the only difference i see is that the new one has grease on the deep inside thread.
    what kind of grease is it?
    could that have been the problem all along!
    thanks all
  16. lanner900
    lanner900 New Member
    May 27, 2014
    New Brunswick, Canada
    Hi- I just fixed this problem.
    The problem was at the end of the shaft. At the end of the shaft is the rubber seat that controls the water flow into the outer tube- note that this seal is actually a spring mounted assembly with another smaller o-ring on the other side. If some corrosion has built up around the end spring mounted assembly, water will leak up inside the inner shaft ( it is hollow) and out that hole by the valve handle. The idea of the spring mounted tip to the shaft assembly is that water pressure keeps the spring depressed and therefore the small o-ring stays forced closed, thereby preventing water from entering the hollow inner shaft. This is all part of how the tap is supposed to be frost free and anti-siphoning. Note also the the entire assembly should be mounted on the house such that there is a slight downward slope to the outside.
Similar Threads: leaking faucet
Plumbing Forum, Professional & DIY Advice Kraus faucet leaking Saturday at 1:43 AM
Plumbing Forum, Professional & DIY Advice Leaking Moen 7385 faucet need help Feb 9, 2017
Plumbing Forum, Professional & DIY Advice Leaking outdoor faucet attached to house Jan 6, 2017
Plumbing Forum, Professional & DIY Advice Water leaking from the bathtub near the faucet Jul 27, 2016
Plumbing Forum, Professional & DIY Advice Water Leaking Out Of Moen Tub Faucet Handle Jul 26, 2016
