Nine Year Old Envirotemp 50 Gallon Water Heater
Discussion in 'Water Heater Forum, Tanks' started by hudson, Apr 10, 2009.
  1. hudson
    hudson New Member
    Apr 9, 2009
    North Carolina
    I believe that it still works like new...but sometimes I suspect reduced performance. Since the kids are all gone, it's hard to really test it.
    It's a model E3Z50RD055V Envirotemp Supreme Lifetime Warranty Self Cleaning purchased Feb. 2000..from Lowes. I still have the receipt and a copy of all of the warranty stuff.
    I'm the original owner...I installed it myself.
    How long will this thing last...Should I swap out the thermostat and elements...or just test everything? ...or just wait till I have real problems?
  2. jadnashua
    No need to replace parts that are working. Symptoms of an electric WH not working would be quickly running out of hot water or really long time to recover.
    You might want to check and replace the anode rod (assuming this has a metal tank...if it's not, then there won't be an anode rod to replace). Those are more correctly called sacrificial anodes, and they literally get eaten up in preference to the steel in the tank, but when they're gone, the tank starts to rust. Most people don't change them, and then the tank starts to degrade. They're used in numerous situations including boats to keep the hull from disintegrating.
    hudson likes this.
    hudson likes this.
  4. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    A bounty hunter like in "Raising Arizona"
    MD
    I guess you could check the recovery rate
    "Recovery rates are generally measured by how many gallons of water can be raised 90-degrees in one hour. If a water heater, for example, stores 50 gallons of water, a recovery rate suitable for radiant heating would be the ability to heat 1 1/2 times its storage amount within one hour. In other words, it could heat 75 gallons each hour. The best water heaters on the market can heat almost three times their capacity."
    You'd have to know the temp. of the incoming water. Turn off the heater, fill it completely with cold incoming water which temp. you have measured, turn it on and time it till it reaches the setpoint, and compare with manuf. spec's.
    If you find any degradation, and knowing that it's 9 YO, you could predict the failure date (when it cannot keep up with demand).
    hudson likes this.
  5. hj
    tank
    The only thing about its description that you have to be concerned about is the "lifetime" portion, and for that you would need your sales receipt. If it is working, leave it alone. If it stops heating properly, test it and replace whatever is broken, and only that. IF it leaks take the tank back and get the new one using your receipt and the lifetime warranty.
    hudson and JerryR like this.
  6. hudson
    hudson New Member
    Apr 9, 2009
    North Carolina
    I've read a good many of the posts in the Water Heater section. My unit was made by Craftmaster, a brand that doesn't have a good reputation. The unit is on a concrete floor...a slow leak probably wouldn't cause big problems...so I just need to fix what's broken and make extra copies of my documentation. When it leaks, I just go to Lowes and they'll replace it with a comparable model.
    It's very nice getting recommendations from those with experience!
    I remember reading one of Terry's posts about a condo unit that required replacements every 10 years.... not a bad idea...then I could get one of the highly recommended units....
    And there's also a pretty good argument that says: If it ain't broke, don't fix it.????
  7. hj
    heater
    Craftmaster is a sublabel of the American Water Heater co.
    hudson likes this.
  8. hudson
    hudson New Member
    Apr 9, 2009
    North Carolina
    I still have this water heater...it's been almost 6 years since the original post and it's working....so the tank is 15. There are no problems. The brochure that came with the WH says that it has 5500 watt incloy elements, a fused ceramic shield tank lining...also 3 inches of non CFC foam insulation. I saved all the papers and receipt...it says that the tank is warranted for the lifetime of the original owner against leaks. Parts also have a lifetime warranty, but they only replace defective parts.
    I wonder how long this WH is going to continue without leaking?
  9. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    A 15 year old water heater could fail at anytime. I doubt that you would get much satisfaction with that "lifetime warranty" but I don't know for sure.
    hudson likes this.
  10. Terry
    Aug 17, 2004
    Hey, it's a good experiment.
    Just make sure it's not in an area where leaking can damage the home. With something that old, a leak can happen anytime.
  11. jadnashua
    Every once in awhile, you'll hear of someone whose WH lasted over 25-years. Much more likely on an electric unit than gas, though. Water quality, use pattern, and design all play a part, as does luck of the draw.
    hudson likes this.
  12. hudson
    hudson New Member
    Apr 9, 2009
    North Carolina
    The 17 year old water heater (It's a model E3Z50RD055V Envirotemp Supreme Lifetime Warranty...made by Craftmaster/American) is located in a garage that is 1 foot lower than the house. The garage door has been replaced with a wall; it's now a heated/cooled utility room...concrete floor still there. A leak would not cause much damage...but it would cause a mess that I would like to avoid.
    What if I installed a drip pan and connected the drip pan to a 3/4 inch high quality rubber hose. I would run the hose through a brick wall into the crawl space...about 50 feet...it's sloped that way...through the exterior brick wall of the crawl space and out towards a wooded lot....everything slopes gradually downhill.
    Or...I probably need to get 3 quotes on getting the water heater replaced with a drip pan and a drain hooked into the house's drain system.
    I keep thinking that I could buy 60-75 feet of hose and a drip pan and do it myself for next to nothing...and I could see how long this old water heater will last. I would be draining the tank in the process...I might learn something about the condition of the tank from draining and disconnecting everything?
