Newbie: ADA toilet for a shallow depth remodel
Discussion in 'Toilet Forum discussions' started by fly2themoon, Feb 5, 2009.
  1. fly2themoon
    fly2themoon New Member
    Feb 5, 2009
    Can any suggest a very reliably flushing toilet for a small (35 sq, ft,) remodel? We are getting rid of the tub, sink, and ancient toilet crammed into this bath that functions as guest bath/ powder room. We would like to install an very reliable ADA toilet in the old not-so-faithfuls's- place. The problem is the toilet is located directly across from the inward swinging door. Current clearance from wall to door swing is 27.75 in. Today wall tile was removed and we may be able to gain another inch (28.75 in.) from wall to door. Rough in is 12" from original wall. Any and all help would be greatly appreciated. Thanks!
  2. Terry
    Aug 17, 2004
    The Toto Dalton CST733F is 26-1/4" front to back with a 16-1/8" high bowl
    The Toto Dreake CST744EL ADA is 28" front to back with a 16-1/2" high bowl
  4. jadnashua
    To gain some design freedom in my bath, I replaced a swinging door with a pocket clearance issues! You need a wall where there is either no or moveable things to gain the clearance (i.e., pipes, ducts, wiring). Or, they also make a sliding door that is entirely in the room like a barn door - it could go either outside or inside the bathroom. Using quality fittings (dual track ball bearing guides), the things are finger tip light and quiet. I opted for a set that could support up to a 300-pound door (mine is nowhere near that), and it was only a few bucks more than the lower capacity version, but it added a lot of strength and longevity (I expect, anyway). Johnson seems to make some of the best...I was not impressed with Stanley and several other brands I found.
  5. fly2themoon
    Feb 5, 2009
    Thanks for the suggestions! I think both the toilets models will work, and the barn/pocket door will be perfect. :)
Similar Threads: Newbie toilet
Toilet Forum discussions Hi Guys, Toilet Newbie. 14 Inch Width and 12 Inch Rough Jun 2, 2014
Toilet Forum discussions Newbie question - Briggs toilet supply Jun 19, 2012
Toilet Forum discussions Newbie – What to do with a toilet flange and T hub after installing a tile floor Apr 3, 2009
Toilet Forum discussions Newbie question Toto Drake CST743S, cleaning rim holes Nov 21, 2015
Toilet Forum discussions older brass copper cast metals appreciation--newbie Jan 30, 2014
