new Uncoupling Mat
Discussion in 'Shower & Bathtub Forum & Blog' started by johnfrwhipple, Apr 9, 2013.
  1. jadnashua
    No idea what kind of strength you'd have with a pull test. The vast majority of stress on tile is in shear, either from bending or if on a vertical surface, just from the weight. As noted, at least as I remember it, the 50psi industry rating is for shear, not pull. I'm not sure I've seen a pull test requirement.
  2. johnfrwhipple
    johnfrwhipple BATHROOM DESIGN & BUILD for both Canada & the US
    Jul 20, 2009
    Design Work World Wide: Bathrooms Vancouver Area
    North Vancouver, BC
    Sorry folks. I removed much of this discussion since it refrenced Ditra and I have quit using and talking about Schluter's products.
    JW - "When it's perfect. It's Good Enough."
    www.No-Curb.com - my blog site on Barrier Free, No Curb, No Dam and Hobless Showers
    (604) 506-6792 jfrwhipple@gmail.com
  3. jadnashua
    On a wall would be more in line with my understanding of the test procedure.
  4. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Post(s) removed by John Whipple
  5. jadnashua
    I think the grout simulates a full wall install better, since it ties the stuff together. Makes it harder for the membrane to shear off, since it's sharing the load across a larger area. But, I have not read the details of the actual test procedure, so may be misinterpreting it.
  6. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    SpiderWeb 2 vs Ditra & Noble Seal TS (Head to Head Challenge)
  7. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Installing Ditra with Ardex AF207
  8. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Thin-set used in testing
  9. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
  10. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Spider Web 2 Testing
  11. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
  12. jadnashua
    The industry tests are after 28-days, the standard for cement based products. After the first week, it has most of the strength. But, also consider that cement continues to gain strength for years, the 28-days was a calculated compromise based on typical construction timelines representing 'typical' strength.
  13. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
  14. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Testing day is here at last
  15. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Pictures of the shear testing control test
  16. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
  17. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Uncoupling membrane - shear testing (Ditra with Laticrete 254 Platinum)
  18. jadnashua
    What's the bonded surface area of the brick? As has been said, a membrane should hold at least 50#/sqin. From a practical viewpoint, I think you've proven you're not likely to strip a tile off the wall easily once the mortar has cured some, at least for Ditra, you've tested.
  19. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
  20. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Ditra Shear Testing - Failure point 1470 pounds
Similar Threads: Uncoupling
Shower & Bathtub Forum & Blog Standard for Uncoupling Membranes Dec 21, 2014
Shower & Bathtub Forum & Blog Noble EZ - Better than any Uncoupling Membrane? Looks like Oct 14, 2014
Shower & Bathtub Forum & Blog What actually does an uncoupling membrane do? Apr 4, 2014
Shower & Bathtub Forum & Blog Tyroc Subflooring - Sound, Moisture and Uncoupling flooring prep Dec 10, 2013
