I have a Gerber brand toilet. I bought a new universal toilet fill valve (Fluidmaster 400A) and a toilet flush valve kit (Oatey #459-269). The box says it has a double thick sponge rubber gasket. I don't know if that means anything special.
The tank-bowl gasket is not sealing. When I flushed with a full tank, a significant amount of water came pouring out from under the tank, I assume from under the gasket. The old gasket seems to sit a little higher when I simply placed on the bowl water inlet compared to the new on. The toilet had three rubber spacer things so that the tank was not sitting directly on the bowl. Are those required or recommended? I removed those so the tank would sit just a little lower and still water came out when flushing.
Any suggestions?
Any suggestions?
