New House old well
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by dubay, Oct 21, 2005.
  1. dubay
    dubay New Member
    Oct 21, 2005
    House is in northern maine, on an Artisian well, Am using a jet style goulds pump, pump is loosing it prime, and when the pump is running, I get only about 27 PSI, pump was in the basement of old house. basement was filled in and concrete slab poured for new house, lines were spliced and buried. I think I already know the answer to this question but am just making sure im right. either im leaking air somewhere in the line or the jet is clogged.
    B Dubay
  2. Pumpman
    Pumpman Pump Sales
    Apr 12, 2005
    Owner - R.L. Peeks Pump Sales
    So. Cal
    Or, the footvalve is bad. I'm assuming, since you said this was an artesian well, that it is under pressure, so it shouldn't be a water level problem.
    Ron
  4. rshackleford
    rshackleford New Member
    Oct 18, 2005
    Eastern Montana (The Bakken)
    Artesian well or flowing well?
    Could the new elevation of the pump mean that it is no longer getting pressure from the aquifer or is this a flowing well that water has shutin pressure at surface? Perhaps if this is an artesian and the static level was below natual grade there was never a footvalve installed becuase it always had formation pressure.
  5. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    With only 27 psi, I would say the jet is plugged. If you had to do some plumbing with the system you may have knocked enough scale loose to plug it.
    Flowing well or not, a plugged jet is going to cut your pressure about in half.
    The footvalve would be necessary to hold the system pressure once the pump shuts off.
    bob...
  6. rshackleford
    Oct 18, 2005
    Good point on the check valve. thanks.
Similar Threads: House
Pumps and Tanks Well Forum & Blog. Water is life. Water Not Flowing Into House, Is It The Pump? Yesterday at 6:21 PM
Pumps and Tanks Well Forum & Blog. Water is life. How do I maintain a well system in a house I purchased? Tuesday at 2:29 PM
Pumps and Tanks Well Forum & Blog. Water is life. Well-head pipe froze and broke on new retirement house under construction Dec 26, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Pipe from well to house / frost line Nov 19, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Is it ok to run CPVC from polypropylene to well tank in house Nov 9, 2016
