Hi all,
I would like to add a 6" floor drain with a 2" fitting to an existing cement floor in a small (15'x30') 2 story workshop building.
I have a 3" main line running close by (about 12" but could be more or less if needed) to the location of the new drain. How can I vent this drain "easily" I believe I do need to vent? I'm also not sure how deep line is buried below the floor.
The only thing upstream from this is a toilet (which looks to be on a sanitary tee and the vent line continues up.) The only thing downstream is a double laundry tub that is vented to up above the toilets location.
Can anyone give any pointers?
Thank you in advance.
