Need help with shower valves
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by beebedb, Oct 3, 2013.
  1. beebedb
    beebedb New Member
    Oct 3, 2013
    california
    I have this old valve assembly which I can not find the correct replacement valves for. The body has no markings on it other then tub/shower ports. I prefer not to replace the entire assembly but rather just the valves. Attached is a picture from the back of the shower where I broke away the drywall to get a better understanding of what I am dealing with. Have you seen this type of assembly before?
  2. Terry
    Aug 17, 2004
    That picture kind of helps. A better view would be the handle side.
    You are so close to being able to just replace it though.
    Normally we replace with a single handle pressure balanced valve with remodel plate.
    If you go for the repair, you can pull the stems out and bring them down to match them up. You will want to replace the valve seats while you are at it. That takes a tool, which they should have.
  4. beebedb
    beebedb New Member
    Oct 3, 2013
    california
    I hear ya and will most likely be replacing the entire assembly. Was hoping to replace just valves and seats. Problem is I have taken the valve stems to several hardware stores and plumbing supply shops and no one can match the diverting valve correctly. Water valves are no problem. Was hoping you came across this same type unit and know manufacturer and replacement part #'s.
  5. Terry
    Aug 17, 2004
    It's a good thing you weren't paying a plumber to drive around looking for parts.
    That's one reason, it makes more sense to pick out a current offering, one that will have parts for years down the line, and just "get er done!"
    [​IMG]
  6. dj2
    dj2 Well-Known Member
    Aug 13, 2013
    California
    Luckily they still make faucets like the one you have, I just replaced one like this the other day.
    What's good about replacing it is: 1. you get a new faucet with new stems, and 2. it fits the holes, and there is no need for a large oversize cover plate (if you were to replace it with a single handle faucet)
  7. jadnashua
    Technically, you can rebuild that assembly, but personally, I'd prefer a more modern valve that meets current codes. You cannot legally replace it unless you change it to one meeting current codes, and a direct replacement, although it would be legal for a tub only situation, it is not when it contains a shower.
  8. hj
    IF you know who made the faucet, which would be a requirement to get the hot and cold stems, locating the diverter should be a piece of cake, from the same source. NO plumber would EVER cut the wall open to repair that valve. It is ALWAYS done from the tub side of the wall.
  9. beebedb
    beebedb New Member
    Oct 3, 2013
    california
    That's what I'm trying to do but mine is 11' and new are only 8", who makes one that's 11" so I don't have to cut and re-route the galvanized water supply pipes?
  10. hj
    You have to go to a "specialty plumbing supply company". Many "premium brands", such as California Brass, make 11" center valves. You might also be able to make one with two "angle shower" valves, a "two way diverter", and a couple of brass nipples.
  11. jm66208
    jm66208 Member
    Aug 17, 2011
    Kansas City
    Gerber makes a 11" replacement for that assembly. I just went through the same process, and after replacing the stems, founds out that the problem was a cracked valve body.
  12. jadnashua
    I'll repeat, you CANNOT legally replace the valve unless it is one that meets current codes - that means it MUST have anti-scald technology in it. You CAN repair what you have, if you wish. There are add-on antiscald devices that could be made to work with a new valve, but the plumbing can get a little messy. This may become an issue should you desire to sell the house, and would be if you got a plumbing permit and had things inspected (which is also technically required if you replace it).
Similar Threads: Need help
Plumbing Forum, Professional & DIY Advice Need help identifying this Pegasus Kitchen Faucet Feb 11, 2017
Plumbing Forum, Professional & DIY Advice Leaking Moen 7385 faucet need help Feb 9, 2017
Plumbing Forum, Professional & DIY Advice Shower cartridge HL40, Need Help to identify this part Jan 31, 2017
Plumbing Forum, Professional & DIY Advice Bathtub Drain Tie-In - Help Needed! Jan 30, 2017
Plumbing Forum, Professional & DIY Advice Need help with shower/tub faucet Jan 21, 2017
