Spencer518
I'm just finishing remodeling my bathroom. The new vanity counter has an undermount sink, while the old sink was a drop-in/topmount. Now the drain hole is lower in height than the old sink. As a result my trap arm is running uphill to the hole in the wall and the water level is high in the p trap. I know the standard solution would be to lower the drain hole in the wall, but that would be quite difficult for me as the pipe is going through 2 studs in the wall before meeting the vent. I took this photo 15 years ago when the house was being built. The wall is currently dry walled and tiled and it would be major work to move the pipe.
I went to Home Depot and got the PVC to make a new drain. My leak is coming from where the metal tail piece is going into the trap adapter. This connection has standing water in it. I've cranked the nut on top of the trap adapter down pretty hard with pliers, but a tiny amount of water is still leaking out. Not the best photo, but you can see some water on the top of the plastic nut. How can a create a permanent water tight seal here? I don't care if it means that the connection can't be undone. At this point I just want this thing to stop leaking. Is there some type of sealant or epoxy that I could apply. Thanks for any advice. Spencer
