rolls831
I've installed a Toto CST743S, and I have a leak in the bolt that holds the tank to the body. Facing the unit, it's the left side, water supply side. At first I thought I tightened the nut to tight. So I removed everything, used a little plumbers putty and re-tightened just snug to hold firmly. After over night there is about a quarter cup of water that drips down the bottom of the end of the bolt. I made sure the 3 points on the under side were touching evenly. What would be your suggestions?
Thank you
Thank you
