My well cap is hissing at me ... I think it's hungry.
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Trenchdigger, Oct 26, 2008.
  1. Trenchdigger
    Trenchdigger New Member
    Oct 26, 2008
    Unemployed! Shoot me an offer. :)
    Newtown, CT
    Hi!
    Until today, I paid it no mind, but my well cap has been hissing for a few months now. Today, the hissing got louder, and the circuit breaker has tripped twice in two days (could be the sign of a failing pump.)
    I've tried googling a good answer, but have not been successful.
    I do not know anything about the well pump, so don't ask. :p It has been working fine for five years (Length of time I've owned the house.) There is a new filter, and the pressure in the tank is fine (Both inbound, and outbound.)
    Does the well cap create a seal? It could be possible the seal is compromised; I hit it with the tractor a few times.
  2. 99k
    99k Radon Contractor and Water Treatment
    Aug 16, 2008
    Contractor of Radon Reduction, Testing, and Water
    Fairfield Co.,Connecticut
    The hissing may actually be water spraying in the well casing from the pitless adaptor. I live one town away from you and will PM you with a contact for my well pump guy who is very good.
  4. 99k
    Aug 16, 2008
    It may also be an electrical issue ... still best to have the well pump guy look into it.
  5. Trenchdigger
    Oct 26, 2008
    Newtown, CT
    I pulled the well cap off and took a look down there. It's dark. :p
    After shining a light, it looks like there is a break at the pitless adapter after all. Now to find a how-to on fixing it.
  6. masterpumpman
    masterpumpman New Member
    Mar 26, 2007
    Consult and Teach Well Drilling Internationally
    Virginia Beach, VA
    A job for an expert!
    If it involves servicing the pitless adapter it will probably involve unseating the pump drop pipe from the pitless. This can be touchy for the inexperienced as you could lose the pump; drop pipe and wire in the well requiring a qualified expert to hopefully fish it out.
    I recommend that you call the licensed pump contractor first! It could save you hundreds or even thousands of dollars.
  7. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    I'd take 99k's name and call him!
  8. Trenchdigger
    Oct 26, 2008
    Newtown, CT
    UPDATE:
    Problem fixed.
    There was a broken seal on the pitless valve/adapter. Also, when the pump was pulled, it looked about ready to fail, in an epic way.
    So, we replaced the pump, and 200' of plumbing, and it's all running fine.
    FYI: I used the guy 99k recommended (Trenchy wonders if it was 99k himself ...) did a good job, and was in and out in a few hours.
  9. 99k
    Aug 16, 2008
    I'm glad everything worked out for you ... frank is very good (and no it wasn't me :D)
Similar Threads: hissing hungry
Pumps and Tanks Well Forum & Blog. Water is life. High pitched hissing noise coming from Shrader Valve on pump Jun 2, 2012
Pumps and Tanks Well Forum & Blog. Water is life. Pressurized Well Tank Hissing Jun 4, 2011
Pumps and Tanks Well Forum & Blog. Water is life. Well head hissing when pump is on?? Jul 11, 2009
