csnort
- Messages
- 4
- Reaction score
- 0
- Points
- 0
When this began I started having pressure problems and found that my pressure switch was clicking on and off several times whenever the pressure began to drop. I thought: "bladder tank problem", so I replaced it. No change. Due to drought conditions I feared for my water level and pulled the pump ( 40 feet of galvanized pipe and a 1/2 hp sub-pump ). I checked the water level and had water 20' above the pump level and 130' below. Pump inlet screens were about 75 % covered with scalely rust (did I mention a high iron and silt content?). So I replaced the pump. Put it all back together with a new pressure switch (plastic pipe this time) and still no change. I checked the nipple and piping on the PS and guage and found them to be nearly clogged. Replaced them too. I increased the cut in and cut out pressures to 50/70 from 40/60 and now I get 3 clicks (on / off / on) every time I get down to cut in. The only thing in the line I haven't changed is the check-valve between the well head and the pressure switch ( it looks to be funtioning in good shape visually). Could it be? Any other suggestions?
Also I wonder: 1) The original well driller installed a PVC screen around the submersible pump. Is this necessary? I have had a tough time finding this around here. 2) Is it ok to lower the pump below the slotted well casing (deeper then 40' in my 150' well)?
Thank you all........I have learned a great deal from this forum.
Cranston
Cranston
