Moving natural gas lines in my kitchen
Discussion in 'Remodel Forum & Blog' started by sandysellers, Sep 9, 2006.
  1. sandysellers
    sandysellers New Member
    Sep 9, 2006
    I bought a groovy new gas cooktop, and now I need to have the gasline moved. Can it go across under the floor? I am replacing the vinyl flooring anyway, so this would be fine with me! Guess I should have figured this out be for spending the $1500?
  2. jimbo
    jimbo Plumber
    San Diego, CA
    If you have a basement or crawl space under the kitchen, this should be OK. Virtually every municipality requires a permit for ANY work on gas lines. Some places allow a homeowner to pull the permit and do his own work, other places do not allow that. Check with your development services department.
  4. hj
    gas
    What kind of floor is it? If it is concrete then the answer is absolutely not.
  5. sandysellers
    Sep 9, 2006
    The floor is above a finished basement, with wooden joists and wooden subfloor (I hope those are the right terms and spelling)
  6. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    The pipe can go there, but I strongly advise you to have a professional do the work. Not only do you want the job done correctly to avoid safety issues, but since this will be in the ceiling of a finished room, you want it to look good too.
  7. sandysellers
    Sep 9, 2006
    So, they will go throught the ceiling in the basement and not through the floor in the kitchen? Guess I called that wrong! The area in the basement is in a large storage closet- makes the need for perfect patching a little less critical. I fully intend on having my favorite plumber, Dale, do all the gas work. He has restored my faith in the plumbing profession: Shows up on time, sticks to his estimate and leaves no mess. God Bless him! If you need a plumber in Davis County,Utah, let me know!!!
  8. Gary Swart
    Sep 1, 2004
    Yakima WA
    The "picture" I have is that the kitchen is over the basement which means ceiling of the basement is the floor of the kitchen. (Joists inbetween of course) I suggest you get your friend Dale over to examine the job and then go with his recommendation.
Similar Threads: Moving natural
Remodel Forum & Blog Bonding agent for PIA regrout job. I want 4th time to be the last. Tenant moving in. Dec 22, 2013
Remodel Forum & Blog Removing Ceiling made of drywall, chicken wire, and plaster Nov 28, 2012
Remodel Forum & Blog Tips and Tricks on Removing Top Mount Cast Iron Sink Jul 2, 2012
Remodel Forum & Blog Moving Into New Home - Changing the Locks - Builder Has a Magic Key to Reset Locks??? Jun 8, 2012
Remodel Forum & Blog Moving W/D and floor drain Feb 21, 2012
