Lstanley
Hello all!
I am working on remodeling my kitchen and need to move my sink. Everything is very straight forward other than how am I going to properly install a P trap. As of right now the sink is connected to the right vent pipe. There is a bathroom and laundry room above this area, I am not sure what pipes they are using, if it even matters.
Is there a different way other than hole sawing through the 6 studs that will be in my way and connect it to the pipe it is currently connected to?
If I put it in its new location, with the pipe in the wall, would it be sufficient to run the pipe horizontal for about 2 feet. Then drop it vertically into the basement and have it tie into the drain stack where the two current pipes are coming out of? Since it would still run vertical before venting, is this still considered a S trap?
To clarify it better I attached three pictures with the two options I am thinking about.
I appreciate any and all help!
