Moen Roman Tub spout spins
AzGuy
Arizona
Hello,
I have a moen 4693 valve with a Brantford Roman tub faucet. The faucet spins on the spout. I tightened the set screw however this did not work. I called moen and they sent a new one. As I’m looking at the adjustable spout shank I noticed the shank is warped where the set screw goes. Moen is also sending me a tool to raise the shank to try the set screw up lower. With the shank warped will this even work without possible leakage? Can the adjustable spout shank be replaced?. Or can it be fixed? There is no access to the bottom of the tub as it’s encased in granite. I plan to hire a plumber just want to get some advice. Thanks
