Moen Hand Shower with Slide Bar not flush with tile - Help
Discussion in 'Shower & Bathtub Forum & Blog' started by dmtrunner, Dec 6, 2009.
  1. dmtrunner
    dmtrunner Health care analyst.
    Dec 6, 2009
    Saint George Utah
    I am upgrading my bathrooms to the MOEN Eva line. The guest bath had a Moen Eva line Four-function hand held shower head with slide bar installed. The plumber did not install a shorter pipe attachment (is it called a nipple?) and the mount is not flush with the wall
    [​IMG]
    I am not a professional plumber but it seems to me to the correct installation would require a change in the pipe length and the connection should be flush to keep out water. Am I asking to much of my plumber to do this?
  2. jadnashua
    If the plumber installed the rough-ins AND was told the finished wall thickness (AND it is where he was told it would be), he messed up. There may not be a shorter nipple available and the only way to fix it is either with a (potentially available) trim piece from the manufacturer, or to move the fitting in the wall. If you have access from another room into the wall, that may be possible.
  4. johnfrwhipple
    johnfrwhipple BATHROOM DESIGN & BUILD for both Canada & the US
    Jul 20, 2009
    Design Work World Wide: Bathrooms Vancouver Area
    North Vancouver, BC
    New piece.
    You should be able to remove that nipple with out damaging the other side of the wall. Once removed clean out a little grout so the new piece will go in and not be touching the grout.
    Unscrew the fixture and the brass nipple will either stay in the wall or come out with the fixture.
    Find a shorter nipple or have one made and re install.
    Good Luck.
  5. hj
    Assuming that he did not use the shortest nipple made, and that there is actually a nipple, not just a male elbow or adapter, behind it, then it can be relocated.
Similar Threads: Moen Hand
Shower & Bathtub Forum & Blog Help with removing Moen shower handle hub Nov 27, 2016
Shower & Bathtub Forum & Blog Moen Posi-Temp, replacing cartridge of bathtub faucet single handle Sep 26, 2016
Shower & Bathtub Forum & Blog Moen Roman Tub Valve Handle Issue Jun 1, 2016
Shower & Bathtub Forum & Blog Moen Posi-Temp Banbury Model One Handle Tub/Shower Faucet - New install, hard to turn Feb 1, 2016
Shower & Bathtub Forum & Blog Moen single handle shower is slow to fully start and slow to stop Dec 28, 2015
