Mis-Reading the Code
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Bassman, Jul 24, 2010.
  1. Bassman
    Bassman DIY Member
    Aug 25, 2006
    musician
    Ventura, CA
    I'm looking at the CA Plumbing code and it says:
    706.1
    "Changes in direction of drainage piping shall be made by appropriate use of approved fittings and shall be of the angles presented by a one-sixteenth (1/16) bend, one-eighth (1/8) bend, or one-sixth (1/6) bend, or other approved fittings of equivalent sweep."
    I can't figure out why a right angle is not included in this list. Are there no 90 degree bends in drain pipes? Thanks for any help.
    Neil
  2. Terry
    Aug 17, 2004
    You would combine two 1/8" bends.
    A long sweep 90 is equivalent, the same as an 1/8 bend and street 1/8 bend put together.
  4. hj
    Of course there are, but the actual application determines WHICH 90 can be used.
Similar Threads: Mis-Reading Code
Plumbing Forum, Professional & DIY Advice Design for rebuilt stack - does it meet code? Feb 21, 2017
Plumbing Forum, Professional & DIY Advice Code for wall hung boiler in bedroom Feb 17, 2017
Plumbing Forum, Professional & DIY Advice Is my drain/vent plan code compliant? Dec 5, 2016
Plumbing Forum, Professional & DIY Advice 30" code for toilet....15" from center to? Nov 30, 2016
Plumbing Forum, Professional & DIY Advice Foundation Drain to Sump - Code Rqmts? Sep 20, 2016
