Greg Lavin
- Messages
- 2
- Reaction score
- 0
- Points
- 0
I seem to have lost one of the two motor speeds on my Mastercool HC cooler. It's the one with 12" cooling pads, roof mounted with a thermostat. I switched leads on the motor and the "high" speed worked (it had been the one that was failing to operate). There is voltage from the thermostat on both high and low motor settings, so I presume the problem is in the switching module in the dry side of the cooler.
I wonder whether there is something about programming that I should know that might affect this; whether there is a source for parts for the cooler (in the event I need to replace the module - AdobeAir has not responded to my calls or emails); or whether anyone has a "bone yard" of miscellaneous used parts that might include one of these modules; or whether my diagnosis is faulty and anyone has other ideas....
Thanks,
Greg Lavin
Thanks,
Greg Lavin
