Loud Whistle Fleck 2510
ReFLeX
MI
I believe I have a Fleck 2510, with the manual
Nearly a year ago I asked here for help to get this thing running, and it was a great help!
Today I noticed a loud whistle coming from the top, and the brine tank was empty. It lasted several minutes after I heard it regenerating maybe? I was worried so I unplugged the power, and it continued. A few minutes later it stopped. I plugged it back in.
What's going in with it? Should I be worried?
ditttohead
Water systems designer, R&D
Ontario California
Sounds like it was regenerating. Set the time of day correctly and it should regenerate at 2:00 A.M. unless the time of day has been adjusted (the timer you have is adjustable for the time of regeneration).
Your meter is set for only 800 gallons between regenerations. What is your hardness? Are you using this system for iron removal as well?
ReFLeX
MI
In about 2001 a test showed .5 ppm iron, 306po hardness.
We are just my wife and I. The whistle was so loud I heard it upstairs in the living room. I haven't reset the meter, and this happened at 5pm.
ditttohead
Ontario California
The time clock will regenerate the system at 2:00 p.m. in most cases if the time of day is set correctly. The system can be quite noisy during the regeneration process, this is normal.
Your last water test was over a decade ago? You should get a new test done, water supplies change over time. A simple hardness and iron test kit can even be purchased for a very reasonable price, but since ou are responsible for your water quality, a real test would be a prudent decision.
ReFLeX
MI
I bought this as my first house in about December 2012. Someone had written in the data about the water.
The water test for hardness is either:
30 GPO
306 PO
or 30 GPG
Hard to tell the writing.
