Type of pump?
Submersible________
Two wire (no control)________
Three wire (control box)______
Wire Size_________ Wire Length________
or
Jet Pump (above ground)____Stayrite
One or two pipes down the well__2__
Size of Pump?
Motor Horsepower?_______3/4
Pump Model #______________
Date Pump Installed__________
Pumping from?
Cistern tank___________
Pond, lake, river________
Water Well____________
Depth of well_____shallow well_____
Depth to water_________
Pump Setting__________
Pipe Size_________"
Drop Pipe Material
PVC________
Steel_______
Poly________
Well Recovery Rate_______gpm
Well Casing Diameter_______â€
Rock Well__________ Sand Well__________ Other______________
Date Well Drilled____________
Well Casing Material
PVC________ Steel_________ Other_________
Pressure Tank?
Bladder or diaphragm tank (one pipe to tank)______yes___
Size or model of tank_______fiberglass_____Flex lite 22 gallon
Air charge in top of tank, with pump off and water drained_________28___PSI
(check with car tire gauge)
or
Plain Hydro Pneumatic tank (two pipes to tank, one in and one out)_________
Size of tank________________
Pressure Switch Setting?
On 30, off 50 ____yes____
On 40, off 60_________
Other_______________
Pump Control Method?
Cycle Stop Valve model #_________
Variable speed control #__________
Pump Start Relay (sprinkler timer, no tank)__________
Manually turned on and off____________
Pump Protection
Cycle Sensor_________
Pumptec_____________
Low pressure cutoff switch (lever on side)__________
Filters or Softeners____limestone__________
Before or after pressure tank___after
Type of filter________limestone
Bypass available________________
Water Used For?
House Use___yes____ Number of baths___2____ Number of People_______3_
High Flow Showers_______gpm?
Plus/Or
Irrigation with timers___no__
Irrigation with hoses___no
Heat Pump______gpm? No
Problems Experienced
No Water_________________
Water only part time________
Water at all times but weak_____
Air in water_______________
Pressure surging___________
Water Hammer (noise)______
Too Much pressure_________
Other____________________
Pump makes clicking or buzzing sounds____yes, clicks
No Sounds______________
Pressure gauge reading________psi
Other____________________________________
Do you have, and know how to use
an Ampmeter and Voltmeter_____yes_____________
Describe Problem_______When washing machine in basement is used water pressure upstairs drops, air gets in lines. Pump pressure switch seems to be working (replaced it 2 years ago). Bladder is holding pressure. Water flow upstairs (first and second floor) is sporadic until pump finishes and cycles off. This is a recent (few days) problem. Cleaned some sediment from pressure valve hose, Pump comes on when pressure drops to 20, stays on for a few minutes until pressure is up to about 49 when it turns off, gauge drops low briefly and settles at 38. Have a shallow, point well. Don't know how old the pump is, but it could be as old as house (21 years). We have had ample rain.
Submersible________
or
Size of Pump?
Pumping from?
Pipe Size_________"
Drop Pipe Material
PVC________
Steel_______
Poly________
Pressure Tank?
or
Pump Protection
Water Used For?
Plus/Or
