Geniescience
Homeowner
Ya gotta go look at the PDFs. Access is easy and no-one in the world has ever said they couldn't get access.
In more concrete terms, to get access, you remove the wall's flush actuator plate (which a four year old can do), you unscrew two Robertson-head screws from plastic (not hard and can be done with the tip of a steak knife), and then the plastic plate comes off, leaving an opening about the size of the flush actuator plate, that was about 6"x12" until about 2005 and 6"x9" for this year's model plate. You now have all the room you need to both see what you are doing with the moving parts and to get your fingers in there. The parts are right up front and top, so you'd do fine if your arms were only 6" long and fingers 2" long. AFAIC, you never need to stick your entire hand in to touch anything. The opening is far far larger than necessary. I hope this answers your main concern, about accessibility. The second question may then be how often parts need attention. AFAIK, there are no issues with Geberit stuff. It wouldn't surprise me if someone wanted to "take the training course" (that is sarcasm) or barring that, practice removing the plate to see all the stuff, put it back on, and remove it all over again, just to see the stuff again.
David
eidt: I just went and looked, and i realized that if your wall is thicker than average you will need fingers longer than 2". Anyone who services dungeons and castles needs real full-length fingers.
David
