Lights dim on pump start
Pete C
Over the last few weeks I have notice a worsening of the house light dimming that occurs on pump start up.
I have a gould pump. Bought it new in the box from someone on CL maybe 5-6 years ago. It is wired for 110 operation.
I have considered switching it over to 220. I assume it may run better as it is using half the current. Also, I would think this would help with the light dimming on startup.
Another thing I noticed about a week ago was a god awful screech that lasted a second or two on startup. This seems to have gone away. The pump sounds fine once it is running. It does not sound like it has a bad bearing.
What else could cause this? I am wondering about the pressure switch. Once in a great while it hangs up, where I have to go down to the basement and give the switch a thwack with a screwdriver to get it to come on. Could corroded contacts be an issue? Maybe it is having trouble getting enough current on startup. I will open it up and clean the contacts if possible.
Also, my expansion tank has been there as longer than we have (16+ years). It has a fair bit of surface rust. Probably not a bad idea to replace it as well. I have very hard acidic water that has taken out pretty much everything else. Surprised it hasn't eaten through this.
Any recommendations appreciated.
You are right.
I don't know about the screech, but pressure switches are cheap. A clogged nipple can slow the response too. If your nipple is brass, clean it. If the nipple is galvanized, replace it.
What tank is the current good performer?
Well-X-Trol tanks are good. My Flexcon Challenger is doing very nicely, but it does not face acid water. If things are corrosive outside, Flexcon Flex-lite tanks are fiberglass. https://www.flexconind.com/products/well-tanks/flexlite-well-tanks/
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
There would be a lot less current through the centrifugal switch in the motor and everything else if you switch to 230 volt. After 5-6 years the pump has cycled on/off enough to burn the points in the centrifugal switch as well as weaken the capacitor. Bearings are also affected by heat and have a limited number of hours of service built into them. If you are replacing the tank it is a good time to switch to a Cycle Stop Valve control so you can use a much smaller tank while still reducing the cycling. The fewer times the pump cycles, the fewer times the lights will dim, no matter what voltage you are using.
