Level cure and bigger tiles
Discussion in 'Remodel Forum & Blog' started by HoneySuckle, Oct 23, 2007.
  1. HoneySuckle
    HoneySuckle New Member
    Nov 6, 2006
    Do you always use level cure for 20 x 20 tile install? The flooring in question does not look uneven to most of the tile people that came to measure. One woman suggested level cure, two other tile reps said it wasn't necessary from what they saw of my flooring.
  2. HoneySuckle
    Nov 6, 2006
    Okay on 20 x 20 tiles?
  4. statjunk
    statjunk DIY Senior Member
    Jun 28, 2007
    I don't know what level cure is. I think you should make sure that you need it first. You haven't supplied any information in your post to allow anyone to help you.
    How about dimensions of the room and how off level it is?
  5. jimbo
    jimbo Plumber
    I also am not familiar with "level cure" , but have used a product called "LevelQuick" which is a self leveling product to use on uneven floors in prep. for sheet flooring. Ceramic tile can usually deal with irregularites due to the thickness of the mortar. I understand large tiles like yours bring in a whole new dimension of issues. I recommend you check with our friends at the tile forum www.johnbridge.com
    They will have an answer for you.
  6. jadnashua
    The bigger the tile, the harder it is to get a perfectly flat installation. the objective is to keep all tiles in plane so that there are no lips from one to another. On some tile, this is impossible, since the tiles themselves aren't consistent (have warps, cups, twists to them so even on a flat surface, they won't lay flat). The only way to handle those is with a wide grout joint and let the grout bridge the difference.
    Assuming the tile themselves are flat, then there should be no lips between them. Any bump, ridge, etc. the tile sits over can make this much more challenging, and a prefectly level floor makes the job much easier to get a good result. This can be done when setting in the thinset by building it up where needed and thinning it out as well, but takes much more time and skill (and materials in the extra mortar).
  7. HoneySuckle
    Nov 6, 2006
    Good point. I will make sure to discuss this aspect with tile setter who is coming to give quote. I had two tile companies say that the floor was level enough for larger tiles, and only one who was pushing some extra material and labour. Thanks!
Similar Threads: Level cure
Remodel Forum & Blog Do I need primer for this self-leveling operation? Jul 23, 2014
Remodel Forum & Blog Floor leveler under partition wall? Aug 25, 2013
Remodel Forum & Blog Leveling floor joists Apr 7, 2013
Remodel Forum & Blog prehung door install - floor level? Jun 19, 2012
Remodel Forum & Blog Carpenter's Pencil and level in one. Not only that it has a magnet and ruler Dec 8, 2011
