Leaking tub tap.
Discussion in 'Shower & Bathtub Forum & Blog' started by meggie, Mar 6, 2008.
  1. meggie
    meggie New Member
    Mar 6, 2008
    I recently changed the taps on the upstairs bathroom tub. Now when I turn the taps on water leaks down the wall in my daughters downstairs bedroom. I'm assuming that the leak is in the spout connection? Does this mean I have to remove the wall and change the pipes? HELP Meggie:eek:
  2. krow
    krow Plumber
    Feb 11, 2008
    Ontario, Canada
    Exhaust every possibility before you start opening up walls.
    I would try checking for any possible leaks within the spout. See if chaulking tiles or any holes in the tile are possible places that water can get into, including behind the spout.
  4. meggie
    meggie New Member
    Mar 6, 2008
    I've done that allready :(. Since it didn't leak before and now only leaks when the taps are turned on (either tap) I'm guessing that the old pipes (over 30 ) have cracked or broken when I tightened the new spout? :confused:
  5. krow
    krow Plumber
    Feb 11, 2008
    Ontario, Canada
    It would be to your advantage to open the wall on the opposite side of the bathroom to make any repairs
  6. greekguy7
    greekguy7 Member
    Jul 1, 2005
    Illinois
    Exactly what did you replace??
Similar Threads: Leaking
Shower & Bathtub Forum & Blog New tub & shower enclosure - leaking on floor - shower curtain Jan 22, 2017
Shower & Bathtub Forum & Blog Remodel shower stall kits prone to leaking? Nov 8, 2016
Shower & Bathtub Forum & Blog New home - leaking shower arm inside wall Oct 26, 2016
Shower & Bathtub Forum & Blog Bathtub faucet leaking Sep 7, 2016
Shower & Bathtub Forum & Blog Leaking slip over bathtub faucet Aug 26, 2016
