Leaking portable water expansion tank
Saint7
Virginia
Hello, I have a portable water expansion tank, and it is leaking at the blue tip. I’m assuming it’s done for good due to corrosion. However, I don't know what to do other than to use the main water shut-off valve to stop it from leaking drastically.
It has two valves connected on top of the water heater, one is yellow on the right side (“water heater shut off”), and the other one is red on the left side. When I turn the “water heater shut off” valve off, the leak decreases compared to when it is on. However, the expansion tank gets really hot, or hotter than usual.
I turned the red when off for a short period, and the leak started to decrease some more (this was when I turned both of them off,) but I turned it back on because I don't what it does. I believe the pipe of the red valve is hot due to it being the hot water pipe, and the other one being the cold water pipe, but I'm not sure.
I’m just looking for advice until I get a new expansion tank and maybe a new water heater, if necessary.
turn off heater , close both valves is the correct way and safe way to address
Cliffyk
Saint Augstine, FL
"Potable" water--I.e. fit to drink.
Is the "blue" valve a Schraeder type tank air precharge fitting? It may just be that the valve insert is weeping...
it takes like 30 seconds to find out . close valve find out its quicker than me looking at your picture. also yoiu can remove the tank and plug but dont use water heater
Gas water heater down to pilot, water off. Open something up to relieve pressure. and spin on a new tank. Three wraps of tape, and it would also be nice to smear some pipe dope over the tape.
Good to see you Terry!
Saint7
Virginia
Thank you!
