Leaking diverter spout
Discussion in 'Shower & Bathtub Forum & Blog' started by David Mims, Sep 27, 2009.
  1. David Mims
    David Mims New Member
    Sep 27, 2009
    Byhalila, MS
    I'm hopeful ya'll can help a brotha out. I seem to have the only such tub spout on earth and can't find a replacement. It's leaking around the o-ring, which I've replaced. I have another tub with the same fixture, and this spout leaks on both while the other spout seals on both. I think daughter pushed down it and broke the plastic inside but can't get it apart to be sure.
    The stem is about 1 1/2" from the threads to the o-ring. Looks like it's soldered onto 1/2 copper pipe. The o-ring is 3/32" by 1 1/8" od. The spout is threaded on the near end but smooth for the o-ring to seat against farther inside. It appears to have a brand stamp at the base SA surrounded by a C. Hope you can see the picture.
    I just need to know what brand it is and where to find one or one similar to replace it. I am much obliged for any insight you fellars might offer.
    [​IMG]
  2. jimbo
    jimbo Plumber
    San Diego, CA
    It is a Delta RP17453. Available at any good plumbing supply, not necessarily at a home center.
  4. David Mims
    Sep 27, 2009
    Byhalila, MS
    Thanks Jimbo!
  5. hj
    spout
    It would have been hard, if not impossible, to damage the "O" ring, so you may have a different problem. Call Delta customer service and have them send you a complete new spout.
  6. David Mims
    Sep 27, 2009
    Byhalila, MS
    True the o-ring was not the problem. Ordered a new spout online Sunday which arrived UPS last night. Great service from ********, and thanks again Jimbo. Problem solved!
  7. hj
    spout
    Delta might have taken a little longer, but you would not have had to buy it.
Similar Threads: Leaking diverter
Shower & Bathtub Forum & Blog Diverter leaking from inside tube. please help identify/locate part Sep 12, 2015
Shower & Bathtub Forum & Blog Price Pfister diverter valve leaking by Sep 9, 2012
Shower & Bathtub Forum & Blog shower diverter stem leaking - no biggie or repair needed? Apr 13, 2010
Shower & Bathtub Forum & Blog Leaking Diverter - Can't remove May 7, 2008
Shower & Bathtub Forum & Blog Leaking Moen Bathtub Spout Diverter Aug 31, 2007
