Lead or ABS flange
Discussion in 'Toilet Forum discussions' started by SwiftE, Sep 28, 2005.
  1. SwiftE
    SwiftE New Member
    Sep 28, 2005
    Hi everyone,
    Hopefully I won't end up more confused than I already am. :confused:
    I my basement, I have a 3" toilet drain in my concrete slab. It's ABS. I'm installing a sub floor over the slab and afterwards, ceramic tiles, then a toilet. My question is, should I use an ABS flange, or a lead one (with an ABS sleave which slides into the drain pipe) and brass ring? Some say to go with ABS, since it's easy to work with and lead is not, wihle one plumber at the hardware store suggested me to use lead, because if the floor moves just a little, the ABS will crack and since lead is soft, there's no problem.
    I really appreaciate your help on this.
  2. Terry
    Aug 17, 2004
    I would go with ABS for this.
Similar Threads: Lead flange
Toilet Forum discussions Toilet flange - cast iron and broken lead closet flange Nov 8, 2015
Toilet Forum discussions Cast Iron / Lead Flange Condo - Repair / Replace Jul 22, 2015
Toilet Forum discussions Brass to Lead Flange Setup Jul 18, 2015
Toilet Forum discussions Cast Iron Flange leaded on an ABS Pipe, replacing flange Jan 3, 2015
Toilet Forum discussions Lead flange 5/8 in. above floor Jul 21, 2014
