Lead Acid Batteries
Discussion in 'Electrical Forum discussion & Blog' started by GregO, Jul 30, 2008.
  1. GregO
    GregO Member
    Oct 5, 2004
    Virginia
    I'm using 6V and 12V lead acid battery chargers with the following specs:
    Input: 120V 60Hz 18W
    Output: DC 12V 500 mA
    Is there a problem (fire hazard, etc.) with using 5 of these hooked to one outlet using a "Squid" (5 outlet) surge suppressor?
    Thanks! Greg
  2. jadnashua
    It's less than a 100W lightbulb...so, no. You should be okay. Just don't pile them into an enclosed space.
  4. GregO
    GregO Member
    Oct 5, 2004
    Virginia
    thanks
    Thanks Jim.
    Good point; I saw the 18 W and was first thinking V!!! D'oh! I just found out that those transformers draw around 100 mA, so...we're good to go.
    Greg
  5. jadnashua
    Keep in mind they make (and they work, but slowly) soldering irons that only draw less than 20W. You just don't want to pile them all on top of each other - give them a little breathing room.
  6. hj
    What do soldering irons have to do with battery chargers, unless there is something in the posting that I am missing.
  7. jadnashua
    Wattage, heat, burning things, comparison...a continuous heat source in a confined space, possibly insulated, can produce elevated temperatures. Most people think of a torch for plumbing to get things hot. BUt, a small, low-wattage soldering iron will melt solder for an electrical circuit, too, needing the same temperature (but not BTU). It is easily capable of starting a fire.
Similar Threads: Lead Acid
Electrical Forum discussion & Blog City Light leader fell for ‘Indian’ copper con Jun 24, 2014
Electrical Forum discussion & Blog Proper install of power lead cable for suntouch mat Nov 3, 2009
Electrical Forum discussion & Blog More than one hot lead to an outlet Dec 26, 2008
Electrical Forum discussion & Blog What Leads For A Digital Multimeter? Dec 14, 2007
Electrical Forum discussion & Blog Acid -etching clear glass shades? May 2, 2014
