Korky Fill Valve - Water rises very slowly after shutoff
Discussion in 'Toilet Forum discussions' started by John414, Dec 5, 2012.
  1. John414
    John414 New Member
    Feb 9, 2006
    New York
    I just installed a new cap on the Korky fill valve in a Kohler Wellworth toilet, along with a new flapper. I left the lid off for a couple days to watch the water level and was surprised to see that it rises very slowly. When the valve shuts off, the water level is just below the water level line on the tube. When I check it hours later, the water level has risen. Overnight it rises to the top of the tube and undoubtedly overflows into the tube, although I haven't observed overflow. I don't hear any running or hissing or see any bubbling. Do I need a new fill valve?
  2. Terry
    Aug 17, 2004
    Normally replacing the assembly cap on the Korky fill valve does it. You may want to make sure that the float swivels on the hinge and that the rubber seal on the cap is clean.
    www.terrylove.com/korky
    [​IMG]
  4. Towers Plumbing
    Towers Plumbing In the Trades
    Nov 13, 2012
    Salt Lake City, UT
    Ditch the Korky, use a fluidmaster.
  5. jadnashua
    One seemingly unrelated thing to check is your incoming water pressure. Some valves do not like to close if the water pressure is outside of normal range. Anything ove 80psi should be regulated at most to that level (and most people are well satisfied with lower pressures).
    The Fluidmaster is a decent valve but my experience with it is that it does shut off more abruptly, and if there's anything loose, can cause pipes to bang. The Korky shuts off more gradually, and if there's anything on the seal, it may not make it all the way. Also, as Terry already said, if the float is not reinstalled properly, it can hang up which prevents things from turning off.
  6. breplum
    breplum Member
    Oct 2, 2004
    Plumbing and heating contractor
    San Francisco Bay Area
    When the cap assembly doesn't work, then the small rubber seal on float cup arm is probably the culprit. Hardly anyone stocks the float cup except in bone piles. I am pretty fed up with this issue on Korky/Toto fill valves and am inclined to "Ditch the Korky" as Towers Plumbing says (unless you carry the float cup with you as well).
  7. Terry
    Aug 17, 2004
    I just installed two Korky MaxPerformance fill valves today.
    One on a American Standard Cadet 3, and one on a Kohler Memoirs.
    I removed two Fluidmaster valves.
    Both bowls were taking too long to fill, and the Cadet 3 was overfilling the bowl.
    By installing the Korky MaxPerformance, I was able to dial in the bowl fill so that the the tank quit filling the same times as the bowl refill. Saving water and the time it takes to refill. Now about 45 seconds on the refill, not five minutes like with the Fluidmaster.
  8. wjcandee
    wjcandee Wise One
    Apr 27, 2012
    New York, NY
    I can't imagine the need to carry around a float cup with you. No need to repair the 528. Given that the thing can be had for less than $10, by the time you hit the customer's driveway, your labor charge is enough to buy a case of the valves. The cap is a nice way for a homeowner to do a DIY repair, but if the problem is something else, there's no reason to do anything other than simply replace the valve. It isn't worth 5 minutes of plumber-time to diagnose. By then, you could have replaced the 528 and be filling out the bill.
    And it doesn't mean that there's anything wrong with the 528 or that it should be replaced with something else. It's very flexible, quiet, reliable, and easy to adjust to the right refill. A much easier DIY install than a Fluidmaster.
  9. wptski
    wptski Retired Machine Repairman
    Oct 20, 2012
    Warren, MI
    It's been mentioned in other threads that the Korky 528MPK can be purchased at Lowe's. Unless the on-line system is totally incorrect, it shows it as a "store pickup item" so it's not stocked at any location in my area.
  10. Terry
    Aug 17, 2004
    The Lowes around here carries the 528 and the 528MP
    The MP is a few dollars more, but it's adjustable. I've seen them at other hardware stores too.
    In a pinch, you can use Fluidmaster, I just don't like them as well for some bowls. Your typical Fluidmaster 400A is been a bit noisy which counts for something in my book.
  11. wptski
    Oct 20, 2012
    Warren, MI
    Ah! They do carry the 528.
  12. wjcandee
    wjcandee Wise One
    Apr 27, 2012
    New York, NY
    I just did a search on 528mpk at lowes.com, and it says its available in store for pickup or to ship. Al the stores in my area show it available. I just typed in 528mpk nothing more or less. Of course, its different in Canada I discovered.
  13. wptski
    Oct 20, 2012
    Warren, MI
    My bad! It is available in my area. Hmm, I'll consider this when my Fluidmaster 400A dies.
    I do know that Lowe's doesn't stock the Korky 3" flush vavle at all but the flapper can be ordered through them.
Similar Threads: Korky Fill
Toilet Forum discussions New Korky 528 Fill Valve looks like its leaking...bubbling Nov 9, 2016
Toilet Forum discussions Korky fill weirdness- latency / noisy - Free Video included! May 3, 2015
Toilet Forum discussions Korky or Toto fill valve best? Apr 29, 2015
Toilet Forum discussions Korky fill valve problem Jul 22, 2014
Toilet Forum discussions Korky fill valve colors? Jan 30, 2014
