Kohler Rite-Temp Valve Disassembly
Discussion in 'Shower & Bathtub Forum & Blog' started by ziggy96, Oct 1, 2005.
  1. ziggy96
    ziggy96 New Member
    Sep 6, 2005
    [​IMG]
    I am in the process of installing a Kohler Rite-Temp valve(model R304-K-NA) in a new shower installation. I want to disassemble the valve so I can sweat the joints near the valve. I already sweated a theaded female connector to a small length a pipe I need for the installation, and then threaded that piece onto the shower valve. I want to disassemble the valve for the next couple of joints as they are in close proximity of the valve.
    The Home Owner Guide does show exact details of the disassembly. It shows a screw as one of the first parts. I see the two screws that hold the collar on, but when I take those off, the valve doesn't come apart. Am I missing something?
    Instructions for the Kohler Rite-Temp valve here
  2. sulconst2
    sulconst2 New Member
    Jul 11, 2005
    remodeler
    old bridge nj
  4. hj
    valve
    One small item that might make your life easier, so you don't have to come back and ask how to stop the female adapters from leaking. The copper tubing will slide right into the valve, and can be soldered there, so you do not need the adapters.
  5. ziggy96
    ziggy96 New Member
    Sep 6, 2005
    Rite-Temp Valve
    Thanks guys. I got the disassembly done. As far as sweating the pipe right into the valve, how far do you have to have the pipe into the valve or are there stops? And how long do you think I have to heat up the valve before I get enopugh heat to melt the solder? Any tips would be greatly appreciated.
  6. hj
    valve
    There are stops and you only heat it until the solder flows normally.
  7. ziggy96
    ziggy96 New Member
    Sep 6, 2005
    Guys,
    It worked out nicely. Thanks alot. :cool:
Similar Threads: Kohler Rite-Temp
Shower & Bathtub Forum & Blog No water from Kohler Rite-Temp Valve Mar 13, 2016
Shower & Bathtub Forum & Blog Kohler Rite-Temp bath & shower valve, K-T10274-4 Sep 12, 2012
Shower & Bathtub Forum & Blog Installing a Kohler Rite-Temp bath & shower valve, K-304 May 1, 2011
Shower & Bathtub Forum & Blog Problems with Kohler 304-KS-NA Bath and shower Rite-Temp Valve with stops Mar 8, 2010
Shower & Bathtub Forum & Blog problems with kohler Rite-Temp shower valve Apr 22, 2005
