Kohler Class 5 Flush Issue
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Jeff_S, Jun 20, 2013.
  1. Jeff_S
    Jeff_S New Member
    Jun 20, 2013
    Hi all,
    I'm new to this forum and I am searching for an answer to my problem.
    I have a Kohler Class 5 Toilet that is about 5 years old. Last night it stopped flushing. One would flip the lever and it would flush but not fill the tank or bowl. Some water would dribble from under the red cap at the top of the fill valve but that was it. However, if you turned off the water at the shut-off then turned it back on on the bowl and tank would fill normally and flush but the process would have to be repeated to refill the tank and bowl.
    I replaced the original fill valve with a Fluidmaster 400a which is the same as my old Kohler fill valve. Now the canister flush valve won't float long enough to let the bowl fill to its original level. The tank fills fine. It worked perfectly prior to the fill valve issue and subsequent change. I even took the time to match the initial adjustments to my old valve, installed the new one then adjusted it from there.
    This issue seemed similar but not exactly like some of the Class 5 issues I had read on the forum. If anyone has any suggestions I'm all ears.
    Sincerely,
    Jeff
  2. jadnashua
    Do you have one of the Flood-Stop hoses on the inlet to the fill valve? If so, throw it away and replace it with a 'normal' one, and your problem will go away.
  4. Jeff_S
    Jeff_S New Member
    Jun 20, 2013
    Jadnashua,
    No, I don't have a Flood-Stop hose. It is a metal pipe from the shut-off to the base of the Fill Valve.
  5. Terry
    Aug 17, 2004
  6. Jeff_S
    Jeff_S New Member
    Jun 20, 2013
    Terry,
    Thanks for the reply. I took a look at the Performax Fluidmaster and compared it to the 400a and my original fill valve. It matches my original valve, especially the additional flange between the adjuster bracket and the flange above the threads. I'll be installing this on tonight. Hopefully everything should work out.
    Sincerely,
    Jeff
Similar Threads: Kohler Class
Plumbing Forum, Professional & DIY Advice Please Help Me Find a single Chrome-KNOB that fits a Kohler 30467 diverter stem Jan 21, 2017
Plumbing Forum, Professional & DIY Advice Kohler Forte Tall Single Lav Repair, K-10217 Jan 14, 2017
Plumbing Forum, Professional & DIY Advice 1970s(?) Kohler/Bradley/Cole Shower Control Leaks Dec 13, 2016
Plumbing Forum, Professional & DIY Advice Kohler Archer acrylic install question Dec 12, 2016
Plumbing Forum, Professional & DIY Advice Kohler K-560 Bellera Pulldown Kitchen Faucet Oct 15, 2016
