Kitchen sink faucet base leak
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Talisker, Dec 13, 2013.
  1. Talisker
    Talisker New Member
    Feb 17, 2013
    Texas
    I have Moen kitchen sink faucet which has small leak at the base on to granite every time you turn it on for about more than couple of minutes. Even after having black washer gasket at the base, it leaks around the washer gasket. If I were to replace a faucet with plate, would it still leak? Or is there a better solution? I have attached the pictures.
  2. dj2
    dj2 Well-Known Member
    Aug 13, 2013
    California
    First find the source of the leak. Is it coming from the handle down to the base?
  4. asktom
    asktom Member
    Nov 9, 2009
    Victor, MT
    The spout probably needs new O-rings. Pull the spout off, remove the 2 O-rings and match them up at the hardware store. I like to smear a little silicone grease on the new rings.
  5. Terry
    Aug 17, 2004
    Make sure the hand held is on the hose tight. They tend to loosen.
    The spout does not use two O-rings. It's a pull out spout with hand held.
  6. Talisker
    Talisker New Member
    Feb 17, 2013
    Texas
    I had plumber check the handheld hose. It is very tight and hose is not wet. I had also called Moen and they suggested on changing out cartridge. But plumber changed out the whole faucet and it still has leak.
  7. hj
    Some older Moen faucets had an internal "air gap" which would fail and cause a leak like that. IF yours is one of them, Moen sends an upgrade kit which eliminates it.
Similar Threads: Kitchen sink
Plumbing Forum, Professional & DIY Advice Recommended rough-in height for kitchen sink drain? Feb 19, 2017
Plumbing Forum, Professional & DIY Advice Moving kitchen sink and dishwasher, vent question Feb 19, 2017
Plumbing Forum, Professional & DIY Advice Kitchen sink still leaks Feb 15, 2017
Plumbing Forum, Professional & DIY Advice New kitchen, new sink, drain too high! Feb 14, 2017
Plumbing Forum, Professional & DIY Advice Kitchen sink smell from non-disposer side Feb 12, 2017
