kitchen sink drain
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by kenneth wells, May 11, 2009.
can you reroute a kitchen drain, and is it not recommended.
  1. can you reroute a kitchen drain, is it not recommended
    1 vote(s)
    100.0%
  2. can you reroute a kitchen drain, is it not recommended
    0 vote(s)
    0.0%
  1. kenneth wells
    kenneth wells New Member
    May 11, 2009
    :rolleyes:I have had problems with my kitchen sink backing up for over a year now.
    I've tried draino,liquid plumber,plunging to no avail. I called plumbers, they snaked inside the gargage which is under the kitchen, and outside drain...nothing worked ,they told me i need to have the ground dugged up, and replace drain pipes. I was recently told by a friend that I could reroute the drain to another drain location in the house. Is that possible, and is that not recommmended.
  2. Terry
    Aug 17, 2004
    You can run kitchen lines anyway you want,
    The Kitchen waste line would be 2", with 1-1/2" vent and 1-1/2" trap arm.
    If you have a crawlspace, it would be easy to run to existing piping there.
  4. FloridaOrange
    FloridaOrange Plumbing Designer
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    Question asked in your other thread..............
    Where and what is the actual problem with the existing line?
  5. kenneth wells
    May 11, 2009
    The existing line is located in the kitchen , and straight down into the garage. The problem is we can't get it unclogged, because I was told it is too far out to the street to snake it. So I need to dig up the street to access the drain.
  6. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    get someone reputable with a sewer cam and see what is going on before you go to the expense and trouble of changing the drain.
  7. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Something sounds fishy!
    I'd try a second company for a second opinion.
Similar Threads: kitchen sink
Plumbing Forum, Professional & DIY Advice Recommended rough-in height for kitchen sink drain? Feb 19, 2017
Plumbing Forum, Professional & DIY Advice Moving kitchen sink and dishwasher, vent question Feb 19, 2017
Plumbing Forum, Professional & DIY Advice Kitchen sink still leaks Feb 15, 2017
Plumbing Forum, Professional & DIY Advice New kitchen, new sink, drain too high! Feb 14, 2017
Plumbing Forum, Professional & DIY Advice Kitchen sink smell from non-disposer side Feb 12, 2017
