Kenetico 60 water discharge
Discussion in 'Water Softener Forum, Questions and Answers' started by B Skipper, Feb 27, 2010.
  1. B Skipper
    B Skipper New Member
    Feb 27, 2010
    ohio
    I have a 20 yr old model 60 that does not stop discharging water I have taken the head appart and cleaned it, but problem still persists any suggestions
  2. Akpsdvan
    Akpsdvan In the Trades
    Dec 29, 2009
    Business owner/service and sales
    Alaska
    Not knowing a lot of the Kinetico units, I would say that the valve that is to close when in service and not cleaning the other tank is worn and not seating right or that the piston that should be closing is not or it to is worn.
    You might be able to find either a used control head that some one is selling or get the part from some Kinetico dealer..
  4. Skip Wolverton
    Skip Wolverton In the Trades
    Dec 27, 2009
    Owner of SWS Systems. I work on most water treatme
    Ocala, Fl
    With a phillips screwdiver, push down on the center piece of the clear plastic top and turn clockwise slowly. If the water stops, the valve is not advancing to the off position. If not, a drain seal is at fault.
  5. B Skipper
    Feb 27, 2010
    ohio
    Water does not stop, would the drain seal be one of the 4 bigger plungers or could it be a o ring on the pistons?
  6. B Skipper
    Feb 27, 2010
    ohio
    Is it possible to find a used or rebuilt head?
  7. Akpsdvan
    Dec 29, 2009
    Alaska
    There are used ones or rebuilt ones out there.
  8. Lowell
    Lowell New Member
    Apr 13, 2005
    Retired
    Central Ohio
  9. Akpsdvan
    Dec 29, 2009
    Alaska
    Might you be talking about a valve like this one?
  10. Skip Wolverton
    Dec 27, 2009
    Ocala, Fl
    The plungers are the pistons. The drain seals are a cone shaped rubber seal. They are on page 11.
  11. B Skipper
    Feb 27, 2010
    ohio
    Yes looks like that one, is it for sale?
  12. Akpsdvan
    Dec 29, 2009
    Alaska
    This one has orange and 2 on the dial that is under the clear.
    Yours?
    PM if you would like.
Similar Threads: Kenetico water
Water Softener Forum, Questions and Answers Best Water Filter for Low amounts of Iron, Magnesium, and Manganese Feb 20, 2017
Water Softener Forum, Questions and Answers Advice for replacing a water softener for iron removal Feb 19, 2017
Water Softener Forum, Questions and Answers I need a professional’s guidance in replacing my water softener. Feb 13, 2017
Water Softener Forum, Questions and Answers Opinions on treating well water Feb 12, 2017
Water Softener Forum, Questions and Answers Resin in Water Feb 12, 2017
