Is troubleshooting and replace a defrost sensor and/or a defrost circuit board a DIY project?
gfr92y
RVA
Forum Members,
I have a 12-year-old Bryant / Carrier / Model 25HBC336W0030010 heat pump that was given a clean bill of health last October by HVAC repair company A.
Monday night, it frosted/froze up and Tuesday morning, a tech from HVAC repair company B said the refrigerant level was fine but with doing a resistivity test or an ice cube and screwdriver, decided the defrost sensor and defrost circuit board needed to be replaced.
I know essentially nothing about heat pumps, but have sufficient technical acumen to not have any mechanics touch any of my cars or my children’s cars in 23 years (except for aligning and balancing tires).
With your help, can I confirm whether or not the defrost sensor and the defrost circuit board are bad and replace the bad component or both components if that it the practice with Heat pumps?
Thank you very much for your assistance on this project.
Sincerely,
Gfr92y
Fitter30
Peace valley missouri
Have you seen the outside unit coils a block of ice with no heat in the house? If not the defrost must be working. The board and sensor is just unplugs take a pic of the board so u know where all the wires go if u decide to replace them. Coils frost up defrost cycle last 10 - 20 minutes factory set for 90 minutes and is adjustable by dip switches on the board 30-60-90-120.
