Is this shower drain to code?
Discussion in 'Plumbing Code Questions' started by Mikeiii, Feb 5, 2013.
  1. Mikeiii
    Mikeiii New Member
    Jan 27, 2009
    California
    Can a shower drain be added to this existing washing machine drain?
    The pink pipes in the diagram would be new?
    Thanks
    Mike
  2. jadnashua
    No, when the WM was running, it would siphon the proposed shower drain dry. EACH trap needs a vent. Depending on how big that pipe is, you might be able to do it IF you added a vent, but a WM drain line can be problematic. You don't want sudsy water getting pumped into your shower!
  4. Mikeiii
    Mikeiii New Member
    Jan 27, 2009
    California
    Thanks for the answer.
    I know very little about drains but I'm trying to remove a shower wall that contains a vent. (the green wall in the diagram)
    Would there be too many bends in the line to bring the shower drain to the vent in wall A and from there back to the current drain below the green wall?
  5. Mikeiii
    Mikeiii New Member
    Jan 27, 2009
    California
    Would this setup work?
  6. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    If you look at your first drawing you will note that the vents are vertical. They have to be that way to ensure that no waste ever backs into the vent and stays there.
  7. Mikeiii
    Mikeiii New Member
    Jan 27, 2009
    California
    Thanks.
    I'm starting to understand.
    I do have a sink drain with a vent that is vertical but it would be a 6ft run from the shower trap.
    Is that too far?
  8. jadnashua
    The vent must come off of the trap arm before the waste turns down, and must be within 5' with a 2" pipe. It must go vertical before it can go horizontal.
  9. Mikeiii
    Mikeiii New Member
    Jan 27, 2009
    California
    Thanks I think it is going to work.
  10. Sean Beck
    Sean Beck Plumber
    Jun 14, 2013
    Toronto, Ontario, Canada
    You could say that the drain upstream of the proposed pink drain could be a wet vent, and providing that that drain is 1.5", then it can take up to 2FU (fixture units) which would cover the washing machine. You just have to make sure the distance from the trap of the shower to the proposed wet vent would be more than 2 x the diameter of the drain pipe (so probably 3 inches).
  11. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    Most codes only allow wet venting bath groups, so venting past the laundry would not be permitted.
  12. Terry
    Aug 17, 2004
    Right.
    No inspector would allow a washer in any wet vent situation. That washer would suck the trap so fast it wouldn't be funny.
  13. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    Not only that but the washing machine rain has to drain into a 3" or larger horizontal or vertical branch.
  14. frodo
    frodo New Member
    Jun 29, 2013
    plumber
    Mississippi
    can you do this ..[​IMG]
Similar Threads: shower drain
Plumbing Code Questions Indirect waste from an ice machine - to a shower drain???? Jul 8, 2016
Plumbing Code Questions Adding a new shower Aug 1, 2015
Plumbing Code Questions Moving Shower Vent Feb 14, 2013
Plumbing Code Questions Toilet /shower DMV Nov 16, 2012
Plumbing Code Questions Shower valve requires? Jan 9, 2012
